General Category => Maintenance => Topic started by: zoomjay on August 12, 2017, 06:40:20 AM
Title: 1990 FJ 1200 Clutch issues
Post by: zoomjay on August 12, 2017, 06:40:20 AM
I finally have my 1990 FJ together and running (don't ask me about my carb issues).  Finally get it on the road... running real good...  hit the throttle and...  the clutch slips when it really hits the power band.  Ride easy for a bit more... do it again... yep, slipping.
So.. since this bike is not planned to be a long-term part of my arsenal....  (although it only has 24,500 miles on it)...  what are the min parts I need to replace in the clutch?  Cover gasket I get... and am guessing that I need friction disks (is that what they are called??).  If this continues would like to order and get them quickly and cheaply.
Thanks.
Title: Re: 1990 FJ 1200 Clutch issues
Post by: big r on August 12, 2017, 08:19:59 AM
Check the files section. There is an upgrade that includes adding an extra pressure plate as well as adding an extra fiber disc
Post by: FJmonkey on August 12, 2017, 09:16:22 AM
Start with adding a second spring on top the existing one, it will get you down the road a little farther before needing to change the clutch.
Post by: red on August 12, 2017, 05:20:32 PM
Quote from: zoomjay on August 12, 2017, 06:40:20 AMwhat are the min parts I need to replace in the clutch?  Cover gasket I get... and am guessing that I need friction disks (is that what they are called??).  If this continues would like to order and get them quickly and cheaply.  Thanks.
Zoomjay,
If you plan to replace the disks, a complete aftermarket clutch pack can be cheaper and easier.  SEARCH here for options.  There is a factory spec for the thickness of the entire clutch pack; I doubt that you would wear out a clutch in 24k miles, unless you drag race often.  The extra clutch spring might do the job for you, anyway.  Is everything good (not binding or worn) at the hand-lever?
Post by: zoomjay on August 13, 2017, 09:06:53 PM
hand lever and clutch master and slave were rebuilt... so, they are good as far as I know...
