General Category => Parts Wanted => Topic started by: Buz on June 04, 2018, 09:21:28 AM
Title: Need Mikuni BS36 Carb Body Atlanta for 93 FJ1200A
Post by: Buz on June 04, 2018, 09:21:28 AM
I need just a single (1) Mikuni BS36 Carb Body for 93 FJ1200A. I am in Atlanta, Georgia 30115. I'd rather not say how I broke the original.
Thx for your help. Buz
Title: Re: Need Mikuni BS36 Carb Body Atlanta for 93 FJ1200A
Post by: FJmonkey on June 04, 2018, 11:54:06 AM
Normally a broken float pin post. They can be fixed. Check with RPM, they service so many carbs they are likely to have parts. Click the banner above to contact them. Robert should be back in the shop today after the WCR.
Post by: FJ_Hooligan on June 04, 2018, 05:26:51 PM
You need to say which carb it is.  There are differences between positions.
Post by: Buz on June 06, 2018, 10:37:58 AM
From left to right sitting on the bike facing forward, #2. The idle mixture screw was frozen. In an attempt to extract it with the easy-out, I chipped off a large portion of the front half of the idle mixture hole to the extent of exposing some of the threads that the idle mixture screw goes into. The idle mixture screw is toast. I have one on order from RPM. I could try to epoxy or jbweld the piece back on. It is a nice break. I would still worry about an air leak even if it held. Ideas?
Post by: balky1 on June 06, 2018, 12:24:38 PM
If you can find a carb - that is the best idea.
Post by: RPM - Robert on June 06, 2018, 12:28:43 PM
I'll look and see if we have anything in the spares
Post by: racerrad8 on June 06, 2018, 03:25:44 PM
Snap a photo of the broken section. We see a lot of those and 99% of the time the carb body is still usable.
Post by: Kgip2k on July 03, 2018, 06:28:37 PM
Did you find one?
