General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: rjdunn22 on June 20, 2019, 11:28:15 AM
Title: Overflow tube issue
Post by: rjdunn22 on June 20, 2019, 11:28:15 AM
Fuel pouring out of overflow tube on 85 1100
Had tank off to replace choke cable, reinstalled, started bike & fuel started pouring out when running.
Tapped bowls numerous times
Will not leak when running with tank is off so cleaned out tank breather found no obstructions.
Reinstalled tank with no change.
Ran perfect prior to tank removal.
Any ideas?
Title: Re: Overflow tube issue
Post by: ryanschoebel on June 20, 2019, 02:24:58 PM
If it doesnt flow with the tank off, then its a delivery issue. Check your petcock. It may be stuck open, and overflowing the bowls.
Post by: Pat Conlon on June 20, 2019, 04:31:05 PM
http://www.fjowners.com/index.php?topic=46.0 (http://www.fjowners.com/index.php?topic=46.0)
Post by: rjdunn22 on June 21, 2019, 09:26:43 AM
Thanks guys!!
