Strange fuel pump issue
Started by Nimbus, August 20, 2013, 11:34:05 AM
Basically, it sounds like you took the pump relay out of the circuit.....  What does "well ground" mean, exactly??  I've been working as an electronic calibration and repair technician for close to 30 years, and have NEVER heard that term before.............
Quote"I just disconnected the gauges and found the stock wire (grey) going to the original tach and used that wire as well ground and the brown positive...."
Nimbus
FYI, I did not have time to investigate further. I had a leaking fork and had to swap it from spare bike as leg was scored. Am off for a trip up north so everything is on hold until Sept 23rd. :bye2:
92 FJ1200
1953 Nimbus
1988 Honda VFR 400R
2018 Montesa 4rt
2003 Suzuki SV650S
1968 Honda CL450
1976 Honda CB400F
Nimbus
Quote from: RichBaker on August 22, 2013, 07:03:41 PM
The 3 wires going to original tach is what I used, grey for signal to tach, black for ground and brown for positive. All wiring has been checked for open or short. I re-installed the stock gauges to check if I can be back to normal but no, I am still missing power from the igniter after startup. Is there a schematic available for the 92 igniter internals?
92 FJ1200
1953 Nimbus
1988 Honda VFR 400R
2018 Montesa 4rt
2003 Suzuki SV650S
1968 Honda CL450
1976 Honda CB400F
Nimbus
 :dash2: :dash2: :dash2: Problem solved after reading the 'reserve switch' thread. Yup it was my reserve switch shutting down the fuel pump. :yahoo:
92 FJ1200
1953 Nimbus
1988 Honda VFR 400R
2018 Montesa 4rt
2003 Suzuki SV650S
1968 Honda CL450
1976 Honda CB400F
Quote from: Nimbus on September 28, 2013, 03:00:41 PM
I am glad to hear some good came out of that thread  :lol: :lol: That's why the disscussion, we all learn. Good on you getting it solved !
PS, it's the fuel not the ignitor.  :mail1: :lol:  :drinks: :drinks: :drinks:
