Coil relay mod question
Started by fjman, February 19, 2016, 07:28:05 PM
Sparky84
Do you think a solid state relay would work better as no moving parts at high rpm rather than a standard Bosch mechanical one
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
I don't know. I like the idea of no moving parts however, I would not consider adding any more solid state components unless I had the Transpo voltage regulator mod done to assure I had stable voltage.
I suspect those tiny circuit do dads don't like voltage spikes.
My old school coil relay (with a plug base) has been doing fine for over 7 years now....I do carry a spare I can plug in. I gotta say, the coil relay mod sure wakes things up.
Sparky84
Thanks, I know where you're coming from Pat  :yes: that's why the question.
This SSR has a pretty big voltage range, to activate 3-32V dc and can switch 40A, 5-60V dc.
So hopefully no voltage spikes will worry it.
But still unsure
1979 Kawasaki Z1300
Quote from: Pat Conlon on February 16, 2019, 03:39:11 AM
That's the very reason I use SSR's, reliability, no moving parts. The FJ has 4 of them, heat and vibration has had no adverse effect on them.
While reliable in use, there does seem to be a higher incidence of duds new off the shelf. In the last few years I've had a few that have not worked straight from the shop. I now test  them before installion.
Tuned forks
Pat, what do you mean about "wakes things up"?
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
The relay mod provides a full 12 volts to the coils so they get a higher charge and produce a better spark.  This makes the engine start much easier.
I noticed this when I installed Dyna coils.  I don't even hear the starter crank anymore.   The starter button is like an ON switch.  All I have to do is touch it and the motor is instantly running.
Sparky84
Quote from: ribbert on February 16, 2019, 06:46:41 AM
So when you mean be "not working", that's means I should get a couple of spares to be sure and check them all before use, or put in tool kit for spares on trip.
1979 Kawasaki Z1300
Mike Ramos
Quote from: Sparky84 on February 16, 2019, 04:45:13 AM
But still unsure
Good evening & good discussion.
When I had my over charge issue some time ago (see "Accolades" post) I had mechanical relays going the ignition coils, head lights, alternator sensor wire & fuel pump (the latter 3 relays were Panasonic).  All of the coils burned out before the components were damaged by the voltage spike.
Leaves one to wonder if using the rated SSR's (or even higher rated mechanical relays) would have allowed the components to be damaged when the voltage spiked.
As an aside: None the accessory circuits were effected as none were on at the time except the radar detector which (fortunately) has low/high voltage protection built into it.
Ride safe.
Sparky84
So, how do we stop voltage spikes or protect against them?
1979 Kawasaki Z1300
Quote from: Mike Ramos on February 17, 2019, 01:06:24 AM
Do you mean relays?
Quote from: Sparky84 on February 17, 2019, 03:42:06 AM
I have a fuse between the battery and each relay, wouldn't that protect it?
Mike Ramos
Quote from: ribbert on February 17, 2019, 05:45:01 AM
Do you mean relays?
Yes, the relays burned - thanks for catching that.
Mike Ramos
Quote from: ribbert on February 17, 2019, 06:13:40 AM
Excellent question:
You would think so, and each circuit/relay is fused separately, including the main relay going to the fuse block (I have the fuse block located in front of the battery, in the area opened up by eliminating the air box) but the only fuse that eventually did blow, apparently after the damage was done, was the main fuse in the stock fuse block.  No other fuse blew!
It seems as if fuses protect against shorts, however not so much against voltage spikes.
So as not to interfer with the stock wiring, there is a seperate fuse blocck for the accesories located behaind the dash board glove box window .
I'll be away from a computer until Wednesday & post pictures at that time if there is an interest.
Ride safe!
Motofun
They do make fuses that are "fast blow", don't know how fast is fast but they may work.  On the other hand do you really want to install a device that may shut down the circuit on a repeat basis?
'69 Honda Trail 90
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'18 Suzuki GSXR 1000R (track)
'23 Yamaha Tenere 7
