Shane4371
« on: June 17, 2016, 07:48:08 PM » |
I've got preignition from 1/4 to 3/4 throttle,only when hot,i've got uni pods delkivic is slipons,40 pilot jet 117.5 main jet,4 turns out on air fuel mixtue,91 octane in the tank,lifted needles one step high,help
Logged
FJowners.com
Logged
« Reply #1 on: June 17, 2016, 07:59:17 PM » |
downshift.
Logged
Mark O. 86 fj1200 sac ca.
Shane4371
« Reply #2 on: June 17, 2016, 08:07:53 PM » |
Did that!!
Logged
Shane4371
« Reply #3 on: June 17, 2016, 08:09:06 PM » |
Did that!!
didn't help,turbo blue 106 octane stops it tho,91 to 9e octane doesn't help
Logged
« Reply #4 on: June 17, 2016, 08:11:29 PM » |
is this a recent development? pinging in all gears when hot?
what rpm are you shifting at?
Logged
Shane4371
« Reply #5 on: June 17, 2016, 08:16:38 PM » |
Ok my ignition is stock,it's been a issue for some time,in 55th gear at 55 full throttle ping ,from 11st to 2nd full throttle ping,323rd gear at 35 mph full throttle pi,only when hot,not cold
Logged
FJowners.com
Logged
« Reply #6 on: June 17, 2016, 08:21:40 PM » |
go one step colder on your spark plugs.
what sprocket and gear are you running?
Logged
Shane4371
« Reply #7 on: June 17, 2016, 08:24:13 PM » |
17/41 gears,i got nvm iradium plugs,could be the issue?
Logged
Shane4371
« Reply #8 on: June 17, 2016, 08:24:52 PM » |
Ngk
Logged
« Reply #9 on: June 17, 2016, 08:34:50 PM » |
good gearing, go a step colder on the plugs and see if that does it. if you are weighing in over 300 lbs with rider and gear that will have an effect when bike is hot.
I used to have the same problem when hot.
I run 155 air bleeds 42.5 pilots 118 mains up 1 from center on the needles. .880 on the floats.
no pings anymore no matter how hot it gets. also flushed out my oil cooler that was clogged with goop.
Logged
« Reply #10 on: June 17, 2016, 09:33:24 PM » |
Yep, read your plugs.
Valves adjusted? How's your (hot) compression numbers?
Logged
Please get your pneumonia vaccination and Flu shot. Do it now. There is no need for your body to battle a pneumococcal bacterial lung infection or the flu virus when there could be other very serious battles to fight. Hang tight, Stay safe, Covid Vaccine’s close.
Shane4371
« Reply #11 on: June 18, 2016, 03:53:49 AM » |
Not close to 300lbs,I looked the ngk iradium plug and the oem ngk plug are the same heat range.I'll check valves again.
Logged
a.graham52
« Reply #12 on: June 18, 2016, 07:43:24 AM » |
You haven't changed fuel quality have you?
Logged
Shane4371
« Reply #13 on: June 18, 2016, 08:28:22 AM » |
Ok,fellas I'll put this thred to rest,i've discoverd my problem,previous owner did a magnetic pickup mod to it,advanced timing,i've retarded her,no more pinging,thanks all for the help,
Logged
« Reply #14 on: June 18, 2016, 07:44:02 PM » |
Those are some really interesting numbers. :-)
Logged
FJowners.com
Logged
