1984 FJ11 Brake Rotors
Started by Sparky84, September 25, 2017, 04:15:06 AM
wainot-Phil
Hi Alan , I found and measured the 2 x  S/H  FJ1100 Rotors that I have ,Looks like they are worn out ,They only measure about 6 to 6.1 mm ,, better off with the Rotors you have ,,cheers Phil
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
"""Present Bikes""":
FJ1200  94
GSX1400
FJools
Quote from: oldktmdude on September 25, 2017, 06:24:12 AM
      Once you have 320mm rotors, blue spots, EBC HH pads and a 14mm R1 master cylinder, the OEM brakes feel like absolute shit. Try mine in December and see what I mean.  :good2:
This
how you doing Pete ?
Still thinking of something..................
oldktmdude
Quote from: FJools on October 04, 2017, 11:37:26 PM
This
G'day Jools, thought you'd dropped of the edge of the planet, been a long time.
It would be great to have you down here in December for our Manshed Day, still a bed or two up for grabs. My FJ has had a bit of work done to it since we last spoke. Won't go into it now but happy to fill you in when we see you in December. Hope you can make it.
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
FJools
Quote from: oldktmdude on October 05, 2017, 05:40:10 AM
This
   Regards, Pete.
I had !!
I'm not going to commit to anything till that bike is up and running sweet, but fingers crossed we can talk shit over a few coldies eh ?
oldktmdude
   Jools, just get it going good enough to get it down here in December. We'll make it sweet over the weekend. Even if you don't have it on the road by then, drive down in your car and either ride one of my bikes or I'm sure there are others willing to lend a spare bike.
   Alan, my apologies for hi-jacking your thread.
Regards, Pete. :drinks:
2009 TDM 900
2004 GasGas Ec300
FJools
Hi Alan
sorry to hijack your thread...............
Pete, refer to my other thread  :good2:
Sparky84
No Worries Guys,
We are all in the same family.  :drinks:
There is only so much that can be said about brake rotors
Cheers Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
bigbore2
As long as you still have enough thickness to work with, one can resurface the disc surface with an angle grinder and an abrasive pad. Then new pads to break-in and you are down the road
balky1
Quote from: bigbore2 on November 08, 2017, 10:36:35 PM
Angle grinder? Shouldn't it be done on a lathe?
FJ 1100, 1985, sold
FJR 1300, 2009
To remove old brake pad transfer layers, I've had good results using my cordless drill and a Flex Hone brush
Spin the wheel one way, scrub, then spin the wheel the other way, scrub....leaves you with a nice cross hatched surface.
This is used for only cleaning the rotors. Not a replacement for turning your rotors on a lathe.
When changing brake pad compounds (e.g. going from organic to sintered pads or vice versa) you must remove the old material built up on the rotor (called the transfer layer) before bedding in the new pads.
Cheers laddies...
"DO NOT TRY THIS AT HOME" or anywhere.
If you want to resurface your rotors this way, fine. To suggest on a public forum where someone might actually try it is not only a bad idea, it's dangerous. Removing pad material is another thing.
If you think there aren't people out there who consider a cutting/grinding wheel to be an abrasive pad, you'd be wrong. I've seen it.
Pat's on the money, cordless drill speed and a non aggressive tool that's not too senstive to angle or pressure. Not too harsh or hard. IMO an angle grinder is too fast and more likely to burnish than abrade.
There are people out there whose ignorance of all things mechanical beggars belief and there's nothing wrong with that if it's not your thing, until, they fancy the notion of having a go at a few jobs themselves, and that one sounds easy.
I wouldn't even bother commenting on this but we are talking about brakes and ripping into them with a hand held aggressive tool, possibly by a complete novice, on rotors that are only a few mm thick to start with.
IMO
FJ1100mjk
Quote from: ribbert on November 09, 2017, 08:31:38 AM
I wouldn't even bother commenting on this but we are talking about brakes and ripping into them with a hand held aggressive tool, possibly by a complete novice.
Couldn't the same reasoning also apply to those that showcase their bling, such as an automatic chain oiler, stainless steel braided brake lines, or a GPS unit? It's not a stretch to envison a mechanical novice installing items like these and having disastrous results. Either with their install or use.
Where is the line drawn for those that post for the benefit of others, but shouldn't because of it being deemed a dangerous practice by others?
Iron Balls #00002175
www.ironballs.com
Marty, do you have an angle grinder?
If you do, then you know what Noel's talking about. Those puppies spin at 7,000 rpm, along with an abrasive pad would be a bit aggressive I'd say.
Get the right tool for the right job.
Brakes are important.
FJ1100mjk
Quote from: Pat Conlon on November 09, 2017, 11:17:32 AM
Exactly
Yep, See reply #5. You're welcome.
No, but I've spent some time using them over the years.
www.ironballs.com
Quote from: FJ1100mjk on November 09, 2017, 12:27:12 PM
Exactly
So Marty, you, personally, would use this on your brake rotors?
