  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > Reviews: Praise or Rant of ANY motorcycle related business > RPM
News
Pages: [1]   Go Down
« previous next »
  Print
Author Topic: RPM  (Read 3973 times)
CanDman
Super Hero Member
Offline Offline
Gender: Male
CanDman
RPM
« on: November 30, 2017, 11:18:49 AM »
 I am sure this is the 1 millionth post but I don't care. Randy (RPM)..... I received your foam twin filter pods....one set for CanD and another set for Snowy...... I can't tell you how amazing they are.....perfect fit and lightning speed getting them here to Toronto. I am truly thankful for what you do for the group..... drinks
Kev
Logged
RPM
 Logged
Motofun
Sr. Member
Offline Offline
Re: RPM
« Reply #1 on: August 11, 2018, 04:49:32 AM »
Just need to add my 2 cents.  I finally got a chance to ride my '89 with the RPM rear shock.  Took it on a spirited ride over 2 days, perhaps 600 miles.  All I can say is this shock has transformed the bike!  I had already put gold valves in the front forks and a 17" rear wheel but the stock shock was holding it back....not any longer!  Only thing to do now is fix the wooden front brakes.  Thanks!!!
Logged
Hero Member
Offline Offline
Gender: Male
1985 FJ, V&H4-2-1, Sport Demons.
Re: RPM
« Reply #2 on: August 11, 2018, 08:14:29 AM »
Quote from: Motofun on August 11, 2018, 04:49:32 AM
Motfun,
Off topic somewhat:  If you do not have braided stainless steel brake lines, you might consider them, for part of your brake upgrade.  You may need nothing else (well, new brake pads, maybe).  I'd recommend eliminating that splitter between the brakes and the master cylinder, especially if you want to add a fork brace later.  You can run a new SS brake line from each caliper to the brake master cylinder, using a two-hose banjo bolt at the master cylinder.  Most decent hydraulic hose shops will have what you need locally for a custom fit, and they can probably do tinted brake hoses for you.  They make banjo bolts with brake bleeders installed now, so it can be much easier to bleed the front brake hoses.  (Shop around, some places try to charge 'way too much for the banjo bleeders.)
On topic: RPM has done well by me, for everything I ever got from them.  They are a great resource for the FJ.  They have everything I mentioned above, except maybe the banjo bleeders.
Happy hunting.    yes
Logged
Pages: [1]   Go Up
  Print
« previous next »
Jump to:
Loading...
