  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > Yamaha FJ1100 / FJ1200 Running Problems > CLuch lever not working
News
Pages: [1]   Go Down
« previous next »
  Print
Author Topic: CLuch lever not working  (Read 2041 times)
0 Members and 1 Guest are viewing this topic.
ikeman1983
Newbie
Offline Offline
« on: March 20, 2018, 06:05:56 PM »
I have a 1987 FJ1200
Went out this morning to go to work (I always start bike in neutral to warm up) and when I tried to put it in gear, it immediately died. It appears that the clutch lever doesn't disengage the clutch. Any ideas?? Bike has a small oil leak but I check it every day and fill when necessary.
Logged
FJowners.com
 Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Re: CLuch lever not working
« Reply #1 on: March 20, 2018, 07:34:25 PM »
Sometimes the clutch slave leaks. Are you sure it's an oil leak and not brake fluid coming from the slave?
Very simple to put a new seal in the clutch slave.
http://rpmracingca.com/proddetail.asp?prod=Clutch%3AS%2FK&cat=39
Logged
Please get your pneumonia vaccination and Flu shot. Do it now.
There is no need for your body to battle a pneumococcal bacterial lung infection or the flu virus when there could be other very serious battles to fight.
Hang tight, Stay safe, Covid Vaccine’s close.
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #2 on: March 20, 2018, 07:38:47 PM »
A sudden malfunction like that sounds like it may be in the side stand/neutral/clutch switch “safety “ system.
Does it feel like the clutch lever is working?  Does the clutch master still have fluid?
Logged
FJRacer
FJOwners
facebook
YouTube
ikeman1983
Newbie
Offline Offline
« Reply #3 on: March 20, 2018, 08:24:36 PM »
the clutch lever feels softer and easier to pull. Ill have to check on the clutch master fluid.
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
« Reply #4 on: March 20, 2018, 10:36:33 PM »
Quote from: ikeman1983 on March 20, 2018, 06:05:56 PM
This should be a good indicator if it is a mechanical clutch issue or a switch issue as Chris mentioned.
When you pulled the clutch lever in and the bike immediately died...... This could be a Clutch switch, side stand switch problem.... Did you recently change the oil and possibly pinched the side stand switch wire in the oil filter cover?
When you pulled the clutch lever in and engaged 1st gear....Did the bike lurch forward violently? This would be an indication of a mechanical clutch failure, Slave cylinder failure or master cylinder failure.
Logged
1995 FJ1200 Brownie Thunder
1990 FJ1200 Casper
1990 VFR750 RC36/1 Parts Bike
Stolen
1989 FJ1200/1297
IBA #65004
balky1
Hero Member
Offline Offline
Gender: Male
« Reply #5 on: March 21, 2018, 12:21:59 AM »
If it is soft, you have air in the system. You will have to investigate how it got inside. Leaking slave, like mentioned, will be obvious by peeling color around it. Also, lever pivot point tends to wear out and then lever doesn't push the master piston the way it should.
Logged
FJ 1100, 1985, 37000 km
FJowners.com
 Logged
fjbiker84
Sr. Member
Offline Offline
Gender: Male
« Reply #6 on: March 22, 2018, 07:53:07 AM »
If my bike has been sitting for a week or so since it was last run, I have to warm up my clutch after starting or there is a significant crash into first gear.  I do this by pulling the clutch lever in and holding it for several seconds, release it and then repeat several more times.  This is a bigger problem in the colder months.  That said, it sure sounds more like the side stand safety switch - either it's not working properly or it's working and you're forgetting to raise the side stand before engaging the bike in gear.  I ran into this several times when I first bought the bike before discovering the bike had this safety feature.
Logged
Pages: [1]   Go Up
  Print
« previous next »
Jump to:
Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
Your membership helps support the hosting costs of the forum
There are several levels of membership that offers other privileges.
Click here to see the various membership levels.
Loading...
