Any tire gauge that's not a PITA?
Started by Charlie-brm, August 12, 2018, 09:40:14 AM
Yep, just as Rick shows, plenty of clearance on the 90* valve stems when they point to the side.
Because my bike leans to the left when on its side stand, I point the valve stems to the right. Makes adding air easier.
RPM sells the 90* valve stems in black: http://rpmracingca.com/proddetail.asp?prod=M%2FC%3A10mmAVS
A note of caution when ordering the valve stems from anywhere else besides RPM. Make sure the stems are for a 10 mm hole, the correct size hole on the Yamaha rims.
Several years ago (before RPM offered them) I bought some 90* stems off FleaBay and they were for a 8 mm hole. I think I still have them somewhere in my parts bin.
Mine came black. RPM has both I think. Good advice by Pat regarding right side access.
Sparky84
Quote from: Pat Conlon on August 14, 2018, 05:21:09 PM
That's a good point angled towards the right and I don't think I've ever topped the tyres up from the left even when at home on the centre stand, just habit.
They are RPM (where Else) but for some reason I think they are just plain anodised, I do have to find them in my box of RPM accessories.
How tight do you do them up?
Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Urban_Legend
Alan
My angled alloy vales stems are attached with a nut on the inside of the rim. There is a rubber washer on each side of the rim to make an air tight seal.
By going to the right they are pointed uphill and easier to access with air gauges. It also negates having to go around the drive chain
Mark
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
oldktmdude
   The valves I use are chrome finished brass, the nut fits from the outside with  rubber sealing washers, top and bottom. No need to over tighten them as the washers are soft and do not require a lot of pressure to seal. Just a turn or so after finger tight. Never had one leak or come loose in over 7 or 8 years that I have been using them. Got them on all of my bikes.
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Urban_Legend
In my years of riding, I have ony ever seen/heard of 1 failing, with zero issues of the wheel being out of balance. If the tyre guy is doing his job, this should never be an issue.
Mark
My Baby (Sparkles)
Bones
I've got steel ones on mine but have them facing left. I always check my tyre pressures on the centre stand so I can easily spin the wheels to line the valve up, and when at a servo I have myself between the bike and kerb not the other side where some cockwad in a car could run into you. The chain is avoided easy enough.
93 fj1200
79 suzuki gt250x7
oldktmdude
Quote from: Bones on August 15, 2018, 01:51:33 AM
I have mine facing towards to left also, for the same reasons you have outlined.
2009 TDM 900
2004 GasGas Ec300
Quote from: Sparky84 on August 14, 2018, 10:34:08 PM
Alan
Check the link. There is a drop down color selection. Choose black or standard. I tightened the nut on the inside with a small wrench, but only tight enough to compress the rubber seal, and tight enough that I can't rotate the valve by hand from the outside.
