Slipping clutch? Check out the Clutch File section.
Started by Pat Conlon, April 09, 2010, 05:32:36 PM
Seems we have a lot of recurring questions on clutch slipping.
Check it out, hope I did not miss anything. This should help the new folks.
http://www.fjowners.com/index.php?topic=1808.msg14307#msg14307
Alf
FJ1200W
Columbia, Missouri
USA
THXFJ1200
 :blush: I might have a stupid question... -but my momma says stupid is who stupid does- so here it goes.
How does it feel when the clutch is slipping?
I am having the hardest time changing gears, like getting neutral is nowhere there, and first also very hard like kicking it down and I feel like I am destroying the thing.
Is this a sign of the clutch been slippery? I was thinking maybe some of the joins and axels need some lube or so...
I did anyways buy a shifting Detent kit from RPM and will give it a go to install it, but I know I have to remove the clutch anyway, so if this is a clutch issue I could already kill two birds with one shot.
How can I differentiate if the shifting issue is not the clutch? I am starting a thread right now but thought to give it a try here just in case. not trying to hijack this thread at all...
Just thought it should be nice to have a clear image for us new to this what to acknowledge as clutch slipping problems.
Thank you very much.
Ser...
Current: 1992 Yamaha FJ 1200 with ABS
Scooter Honda Elite CH150 fixer-upper
Suzuki Intruder VS800GL down in FL
Past:
Yamaha XT 350
Suzuki DL 650 "Wee-Strom" (first bike)
A slipping clutch is easy to test. Ride where you can accelerate hard safely. Perform WOT (Wide Open Throttle) pulls once you are in 3rd gear. A slipping clutch will allow the engine to spin up to higher revs quickly with no benefit of acceleration. Hard shifting may be a leaking clutch slave or air in the clutch hydraulics. This causes the clutch push rod to push less. This means the clutch plates are still dragging a bit so the gears still have load on them when you are shifting.
Test for clutch slip, then report back...
Cat Cracker
Barry Lupton 1985 Yamaha FJ 1100
2001 Kawasaki ZRX1200R
1980 Yamaha RD 350LC
1984 Yamaha RD 350 YPVS
1975 Honda 400 Four Super Sport , Yoshimura Big bore Kit,           Box Section Swing Arm
1982 Kawasaki Z 400 J
1983 Kawasaki GPz 1100
Waiex191
This is timely for me because I think my clutch is slipping at WOT and high RPMs. For now I'm just avoiding that bit of fun because 1) I want to get back to the airplane and 2) no problem keeping up with the V30 Magna.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
THXFJ1200
Quote from: FJmonkey on June 09, 2019, 12:22:36 AM
It was a leaky slave cylinder, its been fixed now, thanks.
Past:
Yamaha XT 350
