Clean brake calipers seals
Started by Scottie1, November 12, 2018, 01:53:55 AM
Scottie1
I have taken apart the front brake calipers and took the seals off to replace with new ones. I have been cleaning and soaking the calipers in soapy water and using a toothbrush and a wooden tooth pick to clean the seal grooves but there is still some crud left that just won't come out. Is there a better way of doing this or a product I can use.
1986 FJ1200
1982 XJ750 R Seca
Quote from: Scottie1 on November 12, 2018, 01:53:55 AMI have taken apart the front brake calipers and took the seals off to replace with new ones. I have been cleaning and soaking the calipers in soapy water and using a toothbrush and a wooden tooth pick to clean the seal grooves but there is still some crud left that just won't come out. Is there a better way of doing this or a product I can use.
Scottie,
Did you try Brake Cleaner, in an aerosol can?  You may want to wrap around the pistons inside the grooves with non-synthetic knitting yarn, or thin strips of cotton cloth, to hold the solvent in place for a time.
Scottie1
Yeah I've tried brake cleaner even let it soak for a bit and it didn't really remove much. I have seen someone used a brass dremmel wheel but I don't really want to try that just Incase it scuffs up the inside.
1986 FJ1200
1982 XJ750 R Seca
Ever try Sea Foam? That shit is magic.
Scottie1
Just soaked them in that and used a small tooth pick it's coming out. Thank you for letting me know Seafoam will do that.
1986 FJ1200
1982 XJ750 R Seca
CutterBill
Stainless steel wire wheel on a Dremel works great... very quick and easy. Never had a problem with fluid leakage; the seals seem to be very tolerant of any minor imperfections. Make sure the pistons are perfect; clean with scotchbrite pad.
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
TomJK
Quote from: CutterBill on November 16, 2018, 05:42:14 AM
Bill
Same here, used Dremel with softbrush and metalpolish, worked fine, see pic...
TomJk.
Past bikes : BMWR90-S,BMW R100CS, Ducati 900SD, Kawasaki GPZ600,Yamaha FJ1200,Kawasaki ZZR 1100 (4x),Kawasaki ZZR1200, Honda CBR1100XXX,Yamaha Thunderace, Kawasaki ZX10R (3X),
Aprillia Falco,Honda CBR600F4I, bikes today : Kawasaki ZX10R (C1, the best!),Yamaha FJ1200, soon to come Kawasaki Z900.....
