  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > FJ Project Writeups > CMR racing products F1 frame
News
Pages: 1 [2] 3   Go Down
« previous next »
  Print
Author Topic: CMR racing products F1 frame  (Read 4939 times)
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
Re: CMR racing products F1 frame
« Reply #15 on: March 08, 2019, 11:59:11 PM »
Quote from: Indiana jones on February 17, 2019, 12:14:54 PM
On the lookout for a free flowing, sprung exhaust system now.
The RPM exhaust to my knowledge is a free flow exhaust. Extremely light weight and his held together by springs.
http://rpmracingca.com/proddetail.asp?prod=RPMHeader
Logged
1995 FJ1200 Brownie Thunder
1990 FJ1200 Casper II
1990 VFR750F The Red Rocket
Stolen
1989 FJ1300
IBA #65004
 Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #16 on: March 09, 2019, 03:05:46 AM »
Quote from: fj1289 on March 08, 2019, 11:13:57 PM
That’s funny!   I’d assume it would have to be custom fabricated ... stainless?  Or TITANIUM!!
A nice XJR system might need the link pipe modified a small bit at most.
For that reason, stainless would be preferred.
The engine is still the same.
Logged
BMW R1150GS,XT600 Tenere,FJ1100 bobber, Ducati 999 BiP x 2
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #17 on: March 12, 2019, 07:42:46 PM »
I enjoy Kevin Cameron’s articles:
https://www.cycleworld.com/exhaust-pipe-retaining-springs-50-ways-to-get-it-wrong
I remember breaking springs in the old days before swivel hooks.
Only Kevin could make exhaust pipe springs interesting.
Fred, does the RPM system use swivel springs?
Logged
Tips for new FJ owners:
1) Don't have an Owners Handbook? You need one: http://tinyurl.com/79fgk5
2) '84-'87 FJ owners: Safety wire your fuel petcock. Do it now: http://tinyurl.com/l982s8w
3) Replace your oem rubber brake lines. They are long overdue. Do it now.
4) ATGATT: Skin Grafts SUCK
Administrator
Super Hero Member
Offline Offline
Gender: Male
Team RPM
WWW
« Reply #18 on: March 13, 2019, 06:08:20 AM »
Quote from: Pat Conlon on March 12, 2019, 07:42:46 PM
Nope. The springs do have the rubber sleeve,but no swiveling ends.
So after many hundreds of thousands of miles ridden on the RPM header system I have never heard of any broken springs.
Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #19 on: March 17, 2019, 05:25:32 AM »
Quote from: aviationfred on March 08, 2019, 11:59:11 PM
I will have to try source something in Europe.
Shipping and tax makes everything overly expensive from North America.
My budget is screwed after buying the frame.
When it is all added up,it wouldn't have been much more expensive to buy a Harris F1 frame.
But I don't see the advantage of the old school, brass welded Harris frame ,apart from it being period correct,and more desireable.
Sure, more flexibility was required back in the 80s with the tyre and suspension tech that was available.
Also, the likes of the TT circuit was a lot bumpier back then,as were most circuits,I would imagine.
I'm looking at a set of Moto Martin headers on Fleabay with a flat 4 into 1 collector box with a 57mm outlet.
Granted a 4-2-1 set up would be better.
Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #20 on: March 21, 2019, 05:39:15 PM »
Boom. Stainless,sprung Akrapovic 4-2-1.
Logged
 Logged
JMR
Hero Member
Offline Offline
« Reply #21 on: March 22, 2019, 08:51:11 AM »
 That's a good pipe.
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #22 on: March 22, 2019, 11:05:59 AM »
I've always wondered for racing purposes....On a 4-2-1 system, if the engine firing order is 1-2-4-3, for proper merge design and scavenging shouldn't the #1 and #4 primaries be connected together and the #2 and #3 be connected?
....it would mean the #1 pipe would have an uneven length in order to cross over #2/3 to connect to #4, or vice-versa, so I suspect that it's more important to have equal length primary pipes vs merge design based of firing order.
All this stuff must have been figured out on a dyno.
Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #23 on: April 02, 2019, 01:44:07 AM »
Most of the TT spec and Phillip Island bikes have a 4into 1 config, obviously the preferred set up when the budget is there. I'll have to settle for the poor mans choice.
I have located Nova close ratio gears for the standard tranny.
Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #24 on: April 09, 2019, 11:22:00 AM »
Hanging up there nicely
Logged
Super Hero Member
Offline Offline
« Reply #25 on: April 09, 2019, 12:22:39 PM »
Wow!!! Fj porn!
Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #26 on: April 15, 2019, 05:00:28 PM »
An 11000 mile xjr1300 engine is now going to be the basis for my race engine build.
I'll get it in the frame,as is, while I'm getting a head done.
I can get it wired and running.
Logged
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #27 on: April 16, 2019, 12:15:42 PM »
Awesome progress!  Can’t wait to see/hear the finished bike used in anger!
Logged
FJRacer
FJOwners
facebook
YouTube
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #28 on: April 16, 2019, 05:35:22 PM »
I’ve been told that a lot of the race car guys sleeve the XJR cylinder blocks for durability. It seems that with the XJR’s  oem Niksil plated aluminum bore trends to oval under hard use.
What are your plans for your engine?
Logged
Indiana jones
Jr. Member
Offline Offline
Gender: Male
« Reply #29 on: April 18, 2019, 06:15:45 PM »
I've been chatting to Roger Winfield about the best pistons, etc.
His super reliable motors run std xjr13 pistons in std bores with zero problems. Any engine failures have been attributed to pushing things a little bit too far in the revs.
I'm pretty sure he's run an engine for 2 seasons and a precautionary strip revealed minimal wear.
I'll be hoping to get around the 140hp mark with head work,full system, stage 1 Yoshi cams, Mikuni 38 flats and a Dyna ignition.
I have a beautiful lightened crank but I think this will have an adverse effect on power delivery.
I have some Nova close ratio gears to help close up the gaps between gears.
I'll be using a Barnett spring conversion till I can afford a Sigma slipper unit of work out how to convert a zx10r clutch, apparently super reliable and smooth.
Logged
 Logged
Pages: 1 [2] 3   Go Up
  Print
« previous next »
Jump to:
Loading...
