  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > FJ Project Writeups > Repair of the Christmas roasted FJ
News
Pages: 1 [2] 3 4   Go Down
« previous next »
  Print
Author Topic: Repair of the Christmas roasted FJ  (Read 8535 times)
Old Rider
Hero Member
Offline Offline
Gender: Male
Re: Repair of the Christmas roasted FJ
« Reply #15 on: January 10, 2019, 10:48:16 AM »
My guess is there was a backfire trough the carb that set the podfilter on fire.
Logged
 Logged
Super Hero Member
Offline Offline
« Reply #16 on: January 10, 2019, 05:35:12 PM »
I doubt this is the case on Fred's FJ, but if the main ground wire has a bad connection, I've seen sparks around the shifter lever pivot shaft as ground from the engine finds a path through the shifter linkage back to the frame.
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
« Reply #17 on: January 10, 2019, 06:42:17 PM »
I have used this type of heat shrink/solder tube on aircraft for decades. Recently I have seen these advertised on Facebook and bought the small kit. I am giving these a try on a few of the wire repairs.
https://sharperday.com/products/necs-waterproof-solder-wire-connectors
Logged
1995 FJ1200 Brownie Thunder
1990 FJ1200 Casper
1990 VFR750 RC36/1 Parts Bike
Stolen
1989 FJ1200/1297
IBA #65004
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Sorry I Offended You
« Reply #18 on: January 10, 2019, 06:44:13 PM »
Quote from: Pat Conlon on January 09, 2019, 12:30:19 PM
Rick, remind me, you split a fuel line at the fuel filter, correct?
Correct. The filter was not a Yamaha, and the nipple was slightly large. I'll never know for certain if that was the source of the fire since it turned into a puddle, but I know it was an issue I had planned to address. I put it on a back burner, if you will, but apparently the burner was left on!
Logged
1993 FJ/GSXR 1200 (ABS Delete)
1987 Porsche 911 Carrera (Full Race)
1993 FJ1200 (formerly ABS) IMMOLATED
1993 FJ1200ABS (RIP)
1982 Seca650
jscgdunn
Bronze Contributor
Hero Member
Offline Offline
Gender: Male
« Reply #19 on: January 11, 2019, 12:39:49 PM »
Quote from: aviationfred on January 10, 2019, 06:42:17 PM
Yes these are awesome.....by far the best for joining wires....
Logged
90 FJ 1200 (Son # 2), Stock
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
« Reply #20 on: January 14, 2019, 04:59:46 PM »
An update... The carbs have been sent to RPM. I have been informed that the choke circuit has been jacked up and probably helped in causing my poor gas mileage, idle adjustment issues, and could have contributed to the fire.  ireful
I have also located and ordered replacement parts that were damaged in the fire. All of the parts were sourced from Germany and England. Since I have removed the ABS function, I specifically searched for side panels that had the ABS absent.
While searching, I came across an oil cooler for sale that looked familiar. Upon closer look, it appears to be a RPM oil cooler with the black fittings. I grabbed it and will install it since the bike is down.
I also ordered a fire extinguisher to carry on the bike.
Logged
1990 FJ1200 Casper
Stolen
1989 FJ1200/1297
IBA #65004
 Logged
Tuned forks
$ Contributor.
Hero Member
Offline Offline
Gender: Male
« Reply #21 on: January 14, 2019, 06:49:24 PM »
I'd like to see a pic of that fire extinguisher next to an item we know the size of, like your bike, hand, tape measure, etc.  Please.
Logged
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
« Reply #22 on: January 14, 2019, 08:12:39 PM »
Quote from: Tuned forks on January 14, 2019, 06:49:24 PM
As soon as it arrives, I will post a photo
Logged
1990 FJ1200 Casper
Stolen
1989 FJ1200/1297
IBA #65004
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #23 on: January 14, 2019, 09:39:45 PM »
Come on, man... you got a googler?
Logged
1982 Seca650
Tuned forks
$ Contributor.
Hero Member
Offline Offline
Gender: Male
« Reply #24 on: January 14, 2019, 10:11:07 PM »
Looks to be about 14" or so.
Logged
Super Hero Member
Offline Offline
Gender: Male
'92 FJ1200 ABS
« Reply #25 on: January 15, 2019, 03:06:40 AM »
Quote from: aviationfred on January 08, 2019, 09:09:47 AM
I am considering ordering one of these to keep in my top box.  flag_of_truce
https://www.ebay.com/itm/Portable-Lightweight-Household-Car-Use-Powder-Fire-Extinguisher-for-Hotel-AH-/254025707428?skus=Color:blue&varId=553364343362
I have about six of these on the sailboat, one (and a larger one) in the rock crawler, and was carrying one on the FJ for years after a fellow rider had a huge fuel leak on the side of the road.  “When the place is on fire, no one has ever wished for fewer fire extinguishers.”
Logged
Super Hero Member
Offline Offline
Gender: Male
'92 FJ1200 ABS
« Reply #26 on: January 15, 2019, 03:28:19 AM »
I swear by similar connectors.  When I first bought my sailboat, every foot of every wire was corroded.  I tore it all out and replaced all of it with high-strand, tinned wire and adhesive-sealed shrink connectors from Ancor Marine.  A fellow sailor told me that it was impossible to get more than a few years out of the wire in the salt environment and he’d tried “everything”.  I did that massive re-wiring job 21 years ago...not a hint of failure anywhere to this day.  When the life of me and my passengers may depend on everything going right, I’m not having to chase electrical gremlins.  My rock crawler is wired the same way...for the same reasons.
Logged
Super Hero Member
Offline Offline
Gender: Male
'92 FJ1200 ABS
« Reply #27 on: January 15, 2019, 03:33:42 AM »
Quote from: Firehawk068 on January 10, 2019, 09:38:09 AM
There has been a few instances where I had fuel pour/spray directly onto my just-turned-off FJ engine. It simply boils off and flashes into vapor instantly. No spark + No Ignition.
I was there for one of them...thus my above commentary about fire extinguishers!  Yep...Not at all easy to ignite, but man if it ever did!!
Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
« Reply #28 on: January 15, 2019, 07:31:37 AM »
Randy has found some major problems with the carbs.  shok cray
The choke circuit and mechanical are jacked up. Definitely the cause of my poor gas mileage over the last 17 months. The float levels were out and allowing too much fuel into the bowls. He also found some ham fisted maintenance from previous owner(s). I am the 4th owner. A fuel pump was connected to the carb bank, the #2,3, and 4 carbs filled with full and stopped when the floats came up. The #1 carb stayed open and had fuel pouring out of the throat. The photos are of the #1 carb showing the fuel pouring out and a bit of bad maintenance.  ireful sorry
Logged
1990 FJ1200 Casper
Stolen
1989 FJ1200/1297
IBA #65004
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Half-Fast Fred
« Reply #29 on: January 31, 2019, 08:31:37 PM »
The New Carbs arrived from RPM. I must say, Virgin Carbs sure do look nice.  rofl
I did a bit of wire maintenance. The red connector from the Alternator was corroded so bad that I could not get it apart. A couple of snips and it was gone. My go to fix is Molex connectors. I still have the 4 pin connector at the steering head to replace, a little melted.
I made good progress with the mechanical stuff. The New intake boots, the almost new heat shield, carbs and UNI pods got installed. Holy smokes, getting carbs to seat into new intake boots is not fun. The New throttle cables are connected at the carbs, but hanging loose. I need to remove the original throttle cables after the before mentioned 4 pin connector gets replaced. If I get an early enough start tomorrow, I may be at a point to give it a start.  yahoo
Logged
1990 FJ1200 Casper
Stolen
1989 FJ1200/1297
IBA #65004
 Logged
Pages: 1 [2] 3 4   Go Up
  Print
« previous next »
Jump to:
Loading...
