New ride
Started by rjdunn22, January 09, 2019, 05:27:55 PM
rjdunn22
Hi all
Just picked up a 85 FJ, its been sitting for a few years.
12,000 miles
What should i go through to get it back on the road?
big r
I would start by making sure the gas tank is clean. Clean the carbs. replace most of the rubber bits. Change the brake lines to stainless ones ,new tires.I am sure one of the pro's here will chime and mention anything I missed
ryanschoebel
Big R nailed it. Check the fuel system, and clean and replace everything as needed. Check the fuel petcock,and make SURE it is safety wired. If it isn't, wire it, or buy one that is( see RPM banner above). Replace the brake lines, and thoroughly flush and change all hydraulic fluids.  Bar that, you will find things as you go over the bike, and have fun
1985 FJ1100-- Atlas (SOLD)
1984 FJ1100-- Storm
rjdunn22
Drained tank, filled with non ethanol. New plugs, new oil & filter, new air filter.
I'll go through the carbs this weekend.
Assuming, after all this time the battery is dead and is already on the replacement list, other things would be :-
Empty all old fuel out of the tank, and if there's one fitted, change the in-line fuel filter.
Change oils (engine, forks) & filter, clutch fluid (might end up having to do master cyl and slave cyl seals after a long time sitting) and put in a fresh air filter. Brake caliper pistons might have seized up as well and remember to check front and rear master cyl's (if they haven't seized, seals might still be damaged from old fluid, and the little holes could be blocked, mine were after 8 years parked in the garage) after you've re-done the rest of the brakes and used them a bit, looking for leaks (old seals). The rear brake cyl sits behind the footrest plates and leaks are not easy to see unless you're checking for them.
Make sure the throttle doesn't stick or snag and returns instantly from wide open - and lube the throttle cables - don't want them to be sticky on return the first time you open the throttle and go WFO on the bike.
Personally I'd take apart the suspension linkages and give them a check and re-grease and as a matter of course I'd change the spark plugs.
Those are things that immediately come to mind  :good2: but I'll bet others have plenty more. !!
rjdunn22
I did notice severe oversteer (turned quick) at low speed, what to look for??
Quote from: rjdunn22 on January 09, 2019, 06:38:47 PM
Low tyre pressures, especially front ! - how did I forget to mention tyre pressures - mind you, after standing for 8 years how did I forget to mention NEW TYRES !!!
Quote from: rjdunn22 on January 09, 2019, 06:38:47 PMI did notice severe oversteer (turned quick) at low speed, what to look for?
rjdunn22,
All good advice, above.  Safety wire for the fuel petcock is a MUST.
Check the age of the tires.  (Click the link, and scroll down).  I want to say that FJ tires are about done, after about five to eight years, no matter about the tread left.  The FJ is a strong and heavy bike; accept no compromises on the road rubber.  Toss your old valve stems, absolutely.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
For the 16" wheels, there are few choices; Pirelli Sport Demons (bias ply), Avon (radials), and maybe one or two others.  If Avons are much better than my Pirellis, I have a hard time imagining how that may be.  Getting Sport Demons on the bike was like getting a complete new bike under me.
For air pressures up front, generally, low pressure makes the bike want to turn in, and high pressure makes the bike want to stand up in turns.  The rear should feel planted, but not harsh.  Start at about 38F/42R, and tweak from there.
rjdunn22
Just checked date codes, 11 years old
Time for new shoes
Thanks  guys!
