Rebuilding the fuel petcock
Started by T Legg, January 17, 2019, 08:30:30 PM
balky1
http://www.nrp-carbs.co.uk/shop/index.php?route=product/product&product_id=4140
I did have the problem with this kit though. Small plunger O-ring was leaking. The rest of the rubber parts still work fine after 6 or 7 years.
FJ 1100, 1985, sold
FJR 1300, 2009
stou
stou
Oups... it's out of stock now :-(
I'll write to them to see if they plan to get some more.
T Legg
I spoke with a guy at J&P cycles. He also owns an fj ands has one of their petcock seals sitting on his work bench at home.unfortunately they are too large. It's a good thing the Britt's sell a kit.
T Legg
balky1
Quote from: stou on January 20, 2020, 02:11:17 PM
Description says it will be available end of January.
FJ 1100, 1985, sold
FJR 1300, 2009
stou
I maybe found a good solution. Only time will tell if it's very good or not. I used TPU and 3D printed a seal. I put some fuel in the valve this morning and still no leak. TPU is a very flexible plastic and it have a very good chemical resistance.
stou
Quote from: balky1 on January 22, 2020, 01:32:29 AM
I didn't noticed that. If my 3D printed not work in long terme test, I'll order one when available. But I'm confident that my printed one will resist to the fuel.
T Legg
Quote from: stou on January 23, 2020, 03:02:26 PM
I didn't noticed that. If my 3D printed not work in long term test, I'll order one when available. But I'm confident that my printed one will resist to the fuel.
.        Stou how is your 3D printed fuel petcock selector gasket holding up ?
T Legg
T Legg
I've had my rebuilt petcock fail and flow fuel with no vacume present several times now since I've rebuilt it. Twice I took it apart and could find nothing wrong and it would work again for months after I reassembled it. I then replaced the diagram again and then the plunger o-ring and as before it would work fine until it didn't. This time I took it apart and everything looked perfect again so I put two of the springs for the diagram togethor slipped inside each other not end to end . So far so good. No more leaking and it still flows normally with vacume applied.
T Legg
