  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > Maintenance > Rpm Fork Valves quick question
News
Pages: [1]   Go Down
« previous next »
  Print
Author Topic: Rpm Fork Valves quick question  (Read 1122 times)
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
« on: July 10, 2019, 01:32:18 AM »
Hello Randy, Robert and everyone,
Just doing a leaking seal replacement on the ‘93 FJ, and after pulling the forks apart, I have noticed that one of the valves has a distinct wear mark where the spring has somehow rubbed against it, not sure how that happened. Also found that one of the plastic “washers” around the bottom of the valve was actually caught up in the fork spring approx 3”” up from the valve. I can’t remember back to when I installed these, but the plastic washers are meant to have that split in them? Both look too neat to have been “broken”.
I appreciate any guidance.
Regards
Logged
For photos of my rear wheel swap, heres the link  https://www.flickr.com/gp/[email protected]/62k3KZ
 Logged
Administrator
Super Hero Member
Offline Offline
Gender: Male
Team RPM
WWW
Re: Rpm Fork Valves quick question
« Reply #1 on: July 10, 2019, 06:30:07 AM »
Ray,
I have never heard of the dealing ring falling off before.  I had several people damage one when installing them by letting it come out of the groove and get wedged. This usually cuts the seal.
Yes,  they are a split seal with that angle cut.
I wonder if the seal got knocked off during the installation.
I will have Robert measure the thickness later this morning and let you know.
If the valve did not have the seal installed as you explained. The valve would have not been centered in the fork. That would be the cause if the wear.  I have seen that before and the reason that part of the valve exists.  If acts as a shield to the bypass piston directly behind that part.
No harm with what you are seeing.
Can you measure the thickness of the seals some we see if one just flat wore out and came off the valve?
Logged
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #2 on: July 10, 2019, 06:44:12 PM »
Thanks Randy and Robert, I have measured both and they are 1.8- 1.9mm thick, pretty sure this is ok? I think it might have been an issue during initial install a few years back, not careful enough. Will be taking extra care this time,
Logged
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #3 on: July 10, 2019, 07:33:27 PM »
Found some pretty thick sludge at the bottom of the forks, the oil was black etc. Definately time for a clean and refresh.
Logged
RPM - Robert
Administrator
Sr. Member
Offline Offline
« Reply #4 on: July 11, 2019, 08:28:04 AM »
Quote from: X-Ray on July 10, 2019, 06:44:12 PM
Yes, that is the correct thickness.
Logged
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #5 on: July 11, 2019, 05:35:51 PM »
Thanks Robert  good2
Logged
 Logged
Pages: [1]   Go Up
  Print
« previous next »
Jump to:
Loading...
