  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > Modifications > LED headlight bulb - recommendation
News
Pages: [1]   Go Down
« previous next »
  Print
Author Topic: LED headlight bulb - recommendation  (Read 582 times)
MOTOMYSZOR
Full Member
Offline Offline
Gender: Male
Fj1200 '91 ABS Electro-Train
WWW
« on: August 12, 2019, 12:06:38 PM »
I have installed in my FJ this type of LED bulb:
It is very well visible in day light for other road users .... but that's all.
After nightfall it's range is very poor, there is no difference between HI and LOW beam. Luminous flux is "broken" what cause blinding other drivers......
Maybe You know other LED bulbs without those side effects?
Logged
 Logged
TomJK
Jr. Member
Offline Offline
Gender: Male
Back to the future!
Re: LED headlight bulb - recommendation
« Reply #1 on: August 13, 2019, 04:00:01 AM »
Hi
Before replacing bulb, most important is using a relays for the headlight, with original wiring the voltage at the bulb is too low, I put in a relays and a LED (Beamtec) bulb and the change is radical, at night it is much better then the regular bulb.
Cheers, Tom.
Quote from: MOTOMYSZOR on August 12, 2019, 12:06:38 PM
Logged
Past bikes : BMWR90-S,BMW R100CS, Ducati 900SD, Kawasaki GPZ600,Yamaha FJ1200,Kawasaki ZZR 1100 (4x),Kawasaki ZZR1200, Honda CBR1100XXX,Yamaha Thunderace, Kawasaki ZX10R (3X),
Aprillia Falco,Honda CBR600F4I, bikes today : Kawasaki ZX10R (C1, the best!),Yamaha FJ1200, soon to come Kawasaki Z900.....
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Sorry I Offended You
« Reply #2 on: August 13, 2019, 10:42:22 AM »
Many have gone before you. Generally, I don't know of anyone who has found a significant advantage to an LED headlight conversion with regard to improving the light emitted on the road. This is mainly due to the shape of the reflector inside the light, which the LED's are just not optimized for. I returned to the factory style incandescent bulb (with relay, of course), in a 80/100 watt version that seems to work very well. I think it's a Sylvania Super White bulb from just about any auto parts store. The 80w low beam is a nuisance for some, but I'd rather be seen than not seen. I added two LED driving lights to the engine protection bars that are wired to the high beam switch. When I go to high beams, I can't outrun the lights at 100mph.
Here's a video clip of the view. The first couple seconds is low beam, and you can see the difference when I hit the high beam switch.
Logged
1993 FJ/GSXR 1200 (ABS Delete)
1993 FJ1200 (formerly ABS) IMMOLATED
1993 FJ1200ABS (RIP)
1982 Seca650
MOTOMYSZOR
Full Member
Offline Offline
Gender: Male
WWW
« Reply #3 on: August 13, 2019, 02:22:48 PM »
I just love the fact that LED light is so well visible in daylight.
 So before I will install old fashion bulb I want try other LED-s
I think that I will give a try for this bulb: https://www.ebay.ie/itm/2PCS-H4-50W-Motorcycle-LED-Headlight-Bulb-FITS-Suzuki-Bandit-600-SV650-1999-2003/132565994974?hash=item1edd8c8dde:g:gaMAAOSwihpawlTv
Logged
ryanschoebel
Sr. Member
Offline Offline
Gender: Male
« Reply #4 on: August 13, 2019, 02:40:37 PM »
Rick, do you have a link for those lights? Ive wanted to do something similar, but havent been able to find any lights that I like.
Logged
1985 FJ1100-- Atlas (SOLD)
1984 FJ1100-- Storm
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #5 on: August 13, 2019, 02:59:35 PM »
Quote from: ryanschoebel on August 13, 2019, 02:40:37 PM
I think I found them on Alibaba or something. I'll post a link if I can find em.
edit: Here you go...
Logged
1982 Seca650
 Logged
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #6 on: August 13, 2019, 03:02:09 PM »
Quote from: MOTOMYSZOR on August 13, 2019, 02:22:48 PM
Like many others, you will find the reflector in your headlight negates most of what you're looking for. In any case, consider including the relay. Good luck.
Logged
1982 Seca650
Bones
Hero Member
Offline Offline
Gender: Male
« Reply #7 on: August 14, 2019, 12:37:45 AM »
If you look closely at a halogen bulb you’ll see it has a shield above one element so it directs light to a specific place in the headlight, most LEDs bulbs don’t have that fitted, that’s probably why they shoot light everywhere. I took that into account when buying mine and settled on an Osram LED that has shields built in above the chips to simulate a halogen bulb. Still haven’t ridden in the dark yet to see how far they throw, but leaving for work at the crack of dawn seems to light up the road and signs ok, something to keep in mind.
Logged
93 fj1200
79 suzuki gt250x7
FJ Flyer
Hero Member
Offline Offline
Gender: Male
« Reply #8 on: August 14, 2019, 05:37:24 AM »
If you're looking for daylight visibility, this is what I ended up with for my FJR, as my city commute needs all the help it can get.  I have them mounted on the forks.
https://www.twistedthrottle.com/denali-drl-daytime-running-lights-with-universal-offset-mounting-kit
Logged
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Pages: [1]   Go Up
  Print
« previous next »
Jump to:
Loading...
