  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > Maintenance > Critical part needed
News
Pages: [1]   Go Down
« previous next »
  Print
Author Topic: Critical part needed  (Read 409 times)
0 Members and 1 Guest are viewing this topic.
Spyker6
Newbie
Offline Offline
« on: September 16, 2019, 09:52:04 AM »
Hey Guys,
  I was working with the fuel line routing on my ’84 FJ1100 and managed to break the “Y” shaped connector that feeds the main line from the petcock to the two banks of the carb rack. It just disintegrated! Anyhow, it’s NO LONGER AVAILABLE from Yamaha. Any suggestions?
Thanks,
Mark K.
Logged
FJowners.com
 Logged
RPM - Robert
Administrator
Sr. Member
Offline Offline
Re: Critical part needed
« Reply #1 on: September 16, 2019, 09:57:52 AM »
We have been using these http://www.rpmracingca.com/proddetail.asp?prod=FuelYGravity I don't know what happened to the picture and we are out of stock but I have some more ordered up. It isn't exactly the same angle as the stock fitting but we have had no complaints from.
Logged
Global Moderator
Gold Contributor
Super Hero Member
Online Online
Gender: Male
« Reply #2 on: September 16, 2019, 10:09:14 AM »
Thanks for the reminder Mark. I still have the oem fitting on my ‘84
Did it take much effort to break that 35 year old plastic fitting? Just curious.
You may have just done yourself a favor.
Logged
Tips for new FJ owners:
1) Don't have an Owners Handbook? You need one: http://tinyurl.com/79fgk5
2) '84-'87 FJ owners: Safety wire your fuel petcock. Do it now: http://tinyurl.com/l982s8w
3) Replace your oem rubber brake lines. They are long overdue. Do it now.
4) ATGATT: Skin Grafts SUCK
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #3 on: September 16, 2019, 09:13:51 PM »
Every auto accessory store has a standard selection of mostly plastic and some brass barbed fuel line fittings in several diameters.
T's for vertical or horizontal operation, elbows (L&R), joiners for fuel flow in both directions, splitters, reducers and expanders.
They are usually sold in small handy packs of 2 or 3 and most commonly mounted on a selection board.
Like fuel line itself, this is not something you need to hunt down original parts for.
Logged
“If everyone is thinking alike, then somebody isn't thinking.”
Spyker6
Newbie
Offline Offline
« Reply #4 on: October 22, 2019, 11:46:58 AM »
   The fuel line split as well, right where it mates up with the petcock, so the "Y" part broke as I was trying to remove the other end of the hose from it. It broke easy, just disintegrated, so be very careful if you're messing around there. I found some "T" shaped vacuum fittings to replace the Y part but they were plastic and I wasn't sure if over time they would dissolve, filled with gasoline all the time, so when I found the correct part I went for it. As the official Yamaha fuel line is no longer available either, I tried some generic 3/8" I.D. automotive hose but the O.D. was too big and it tended to kink as it is routed in a circle on top of the vacuum diaphragm housing of carb #3. Then on an unrelated trip to an O'Reilly's Auto Parts store I found a little boxed fuel line kit from Prestone (P/N FUO308) that has a small enough O.D. that it routes nicely under the FJ tank. Got it running soon after that.
Logged
Pages: [1]   Go Up
  Print
« previous next »
Jump to:
Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
Your membership helps support the hosting costs of the forum
There are several levels of membership that offers other privileges.
Click here to see the various membership levels.
Loading...
