  • Home
  • Gallery
  • Help
  • Search
  • Login
  • Register
FJowners.com > General Category > Maintenance > does the FJ fire 2 cylinders at a time 180 degree apart? same all years?
News
Pages: [1]   Go Down
« previous next »
  Print
Author Topic: does the FJ fire 2 cylinders at a time 180 degree apart? same all years?  (Read 1167 times)
0 Members and 1 Guest are viewing this topic.
mtc
Sr. Member
Offline Offline
Gender: Male
« on: May 18, 2020, 12:39:13 PM »
the fire order is 1,2,4,3
so is 2 cylinder firing at the same time while the other 2 is on the exhaust stroke?
or does the motor fire 1 then 2 then4 then3 and  90 degree?
Logged
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
FJowners.com
 Logged
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
Re: does the FJ fire 2 cylinders at a time 180 degree apart? same all years?
« Reply #1 on: May 18, 2020, 12:47:44 PM »
Yes, the coils fire 2 plugs at the same time. Left coil fires cylinders #1 and 4...the right coil fires #2 and 3.
That’s why this sequence is called “wasted spark”
Logged
Please get your pneumonia vaccination and Flu shot. Do it now.
There is no need for your body to battle a pneumococcal bacterial lung infection or the flu virus when there could be other very serious battles to fight.
Hang tight, Stay safe, Covid Vaccine’s close.
mtc
Sr. Member
Offline Offline
Gender: Male
« Reply #2 on: May 18, 2020, 12:58:37 PM »
Quote from: Pat Conlon on May 18, 2020, 12:47:44 PM
are all production 4 stroke 4 cylinders, configured this way?
i read with a cam change( change firing order) this could provide more exit power i.e. traction not that it matter here and now
then why does the 88+ years only have one pick up coil, ? does the upgrade from cdi to the later years TCI have something to do with it?
Logged
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Hero Member
Offline Offline
Gender: Male
« Reply #3 on: May 18, 2020, 01:47:06 PM »
Forgive my potential ignorance, but surely the cam doesn't have anything to do with firing order, it just controls the duration magnitude and timing of the valve seems opening. Once the firing order/sequence has been decided, the crankshaft and ignition are the key factors in engine design to facilitate this, with the cam being designed to work with those two factors to optimise power/torque output for the intended use.
Logged
mtc
Sr. Member
Offline Offline
Gender: Male
« Reply #4 on: May 18, 2020, 02:05:57 PM »
Quote from: Millietant on May 18, 2020, 01:47:06 PM
unsure
read the paragraph on the inline fours called long bang
https://en.wikipedia.org/wiki/Big-bang_firing_order
https://www.r1-forum.com/threads/who-can-explain-the-big-bang-firing-order-in-degrees.261513/
A twingle is a four stroke twin cylinder engine with an altered firing order designed to give power pulses similar to a single cylinder four stroke engine. It is well known that 4-stroke singles "hook up" better than 2-strokes in the dirt. This is because 4-strokes have half as many power strokes per crankshaft revolutions as a 2-stroke. This creates a recovery gap during which the rear tire regains traction.
Logged
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Hero Member
Offline Offline
Gender: Male
« Reply #5 on: May 18, 2020, 02:14:22 PM »
Here's another link explaining the workings of MotoGP Big Bang engines.
https://motomatters.com/news/2008/02/24/guest_column_why_big_bang_engines_work.html
Logged
FJowners.com
 Logged
mtc
Sr. Member
Offline Offline
Gender: Male
« Reply #6 on: May 18, 2020, 02:15:29 PM »
Quote from: Millietant on May 18, 2020, 02:14:22 PM
cool thanks, that is one damn good read, need to finish later but good
Logged
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #7 on: May 18, 2020, 03:53:02 PM »
Quote from: mtc on May 18, 2020, 12:58:37 PM
....are all production 4 stroke 4 cylinders, configured this way?
No, “wasted spark” was only common on old I-4 engines that did not have a cam angle sensor (CAS)
Once CAS was used there became enough resolution for ignition sequence to become “sequential” meaning one cylinder firing at a time. With one coil for one cylinder this allowed the coil a longer time to charge between discharge events. A smaller coil (like pencil coils used with coil on plug set ups) with larger voltage outputs were the result.
You need a CAS signal to tell the ignition when to fire the single coil.
 A crank signal alone will not give you the proper resolution for sequential ignition.
The same is true with fuel injection.
Without a CAS signal you can not run sequential fuel injection. One injector squirting fuel at a time.
With just a crank signal you can run fuel injection, but it’s run in what is called a “batch” mode, which is 2 injectors firing at the same time, similar to wasted spark....except this one wastes fuel.
Modern I-4 engines have a CAS signal so as to be able to trigger sequential fuel injection and sequential ignition.
Clear as mud?
Big Bang engines involved special crankshaft, cam and ignition designs.
The Digital Controlled Ignition (DCI) on the ‘88+ used 1 pickup because only 1 signal was needed every 180* the ignition digitally advanced the ignition timing curve and selected which coil to fire the “wasted spark” sequence.
(FYI: your reference to CDI.... CDI stands for Capacitor Discharge Ignition, a different animal)
2 pickups were needed on the ‘84-87 Transistor Controlled Ignition (TCI) because the analog ignition could not differentiate which coil needed to be fired at which time, so 2 signals were needed, one signal for each coil.
Hope this helps.
Logged
mtc
Sr. Member
Offline Offline
Gender: Male
« Reply #8 on: May 18, 2020, 04:06:00 PM »
Quote from: Pat Conlon on May 18, 2020, 03:53:02 PM
Once CAS was used there became enough resolution for ignition sequence to become “sequential” meaning one cylinder firing at a time. With one coil for one cylinder this allowed the coil a longer time to charge between discharge events. A smaller coil (like pencil coils used with coil on plug set ups) with larger outputs were the result.
Clear as mud?
Hope this helps.
dci,  since it's got 1 pickup, it sees the rotor every 360 degrees no? unless those little protrusions, every 90 degree triggers it?
Logged
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #9 on: May 18, 2020, 04:09:59 PM »
Good catch, I think you’re right....I need to look at a rotor to be sure....
Logged
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #10 on: May 18, 2020, 04:33:19 PM »
The camshaft absolutely determines the firing order - it determines when each cylinder is on the intake, compression, power, or exhaust stroke.  Now, that said, the ignition doesn’t care if cylinder 1 fires “before” or “after” cylinder 4 since it is going to fire both plugs each time anyway.
Actually each “pair” fires 360 degrees apart - the total engine cycle is 720 degrees, not 360.  The “off” pair fire 180 degrees out from the other pair.
The FJ runs a 1-2-4-3 firing order.  A lot of other four cylinder engines (mostly car I think) use a 1-3-4-2 firing order.  The difference is determined by how the camshaft lobes are arranged on the “bump stick”.
There is a guy that has cut and rewelded the camshafts of his FJ in order to make a “Big Bang” engine - 1&4 fire, the 180 degrees later 2&3 fire, then 540 degrees later 1&4 fire again.  Looking for that article again.  Why did he do it?  What was the purpose?  For him, it sounds good!  Lol
Logged
FJRacer
FJOwners
facebook
YouTube
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #11 on: May 18, 2020, 04:42:06 PM »
Thanks Chris, yea, a FJ Big Bang motor....holy crap.... shok
Q: on the ‘88+ ignition rotors, were there 2 timing nubs or just one?
Logged
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #12 on: May 18, 2020, 05:04:07 PM »
Quote from: Pat Conlon on May 18, 2020, 04:42:06 PM
I don’t remember - mine now have 23 (24-1) or 22 (24-2) or 11 (12-1)!   sarcastic
Pretty sure they have 4 - 3 shorts and one long.
The rotor pattern isn’t that important - what is important is the “decoder” reading the wheel.
Logged
FJRacer
FJOwners
facebook
YouTube
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #13 on: May 18, 2020, 05:05:52 PM »
You’re running batch injection, correct?
Logged
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #14 on: May 18, 2020, 05:22:06 PM »
Yes - but the new system on the race bike allows me to run “untimed sequential”.  Biggest advantage is allowing for only 1 injection pulse per engine cycle from each injector — allows it to idle well on 990cc/min injectors!  Normal batch firing requires 2 injection pulses per injector - and doubles the minimum amount of fuel you can inject at idle - too rich to idle in my case.
The “untimed sequential” might end up injecting on the intake stroke or the exhaust stroke.   May make a little difference on idle quality or emissions, but really doesn’t matter for power or torque since the injection time increases while the time to inject is decreasing.  Even on the idle - you probably won’t notice anything other than a change in the AFR of a couple tenths.
Also - a lot of engines that use sequential injection still use waste spark (you can tell by the siamesed coils in the coil packs.
My coils are wired for sequential,  but are fired wasted spark without a cam sensor to determine engine cycle.
Logged
FJRacer
FJOwners
facebook
YouTube
FJowners.com
 Logged
Pages: [1]   Go Up
  Print
« previous next »
Jump to:
Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
Your membership helps support the hosting costs of the forum
There are several levels of membership that offers other privileges.
Click here to see the various membership levels.
Loading...
