Hello my 1984 fj1100 idles at 1000 perfectly accelerates to 5000 strong but then hits a wall feels like choke is on if i go through the gears it will go to redline in every gear but doesnt feel like a 1100 should want to pull your arms out of socket sync carbs ok valves ok i did notice when syncing carbs i attached a external tank and i kept getting air bubbles in the line if i tapt on the carbs could there be air bubbles in the carbs or do they work themselves out? and when i pull plug and check spark against engine yellow spark not blue but when i use inline sparkplug tester its ok thanks in advance for any help
JOEL
Welcome Joel!
What’s the background on the bike?
Did you just buy it? Have you had it a while and it’s always been this way? Did it recently start doing this? Any maintenance Or modifications recently?
There is a lot of experience and expertise on this site - but internet diagnosis is always a bit of a challenge. How does that phrase go - Help us help you!
