mis-reading fuel gauge
Started by pigge7, September 09, 2011, 08:12:18 AM
pigge7
I have a FJ1100 84 and the fuel gauge is showing like 50% of the tank is ful when the tank is 100% ful.
I know there is alote to read about a problems whit the  fuel gauge but not this problem.. (or i have not found it anyway) please help if you can!
Br
Jonas
Directly shorting the connector leading to the sensor should show it as 100% full.  If not, odds are the guage ain't right.  If it shows totally full under a short and totally empty when open, then check with a meter the resistance of the sender itself while running it through range of motion.  Also possibly the actuation float arm is bent or the float ain't right, etc.
pigge7
Quote from: andyb on September 09, 2011, 08:24:49 AM
Thanks I will try this weekend and post how it went!
