  • Home
  • Gallery
  • Help
  • Search
  • Calendar
  • Login
  • Members
  • Register
  • FJRally.com
FJowners.com > General Category > Modifications > Recommend A First Mod
News
Pages: 1 [2] 3   Go Down
« previous next »
  Print
Author Topic: Recommend A First Mod  (Read 2297 times)
$ Contributor
Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
Re: Recommend A First Mod
« Reply #15 on: May 26, 2012, 08:55:52 AM »
Quote from: yamaha fj rider on May 26, 2012, 08:36:16 AM
Wow great stuff. I am new here and love the forum. Please help me understand this mod from the ground up. Seems like the best next mod for my 93 fj1200abs. Two questions why so much dislike for the abs model and why change the rooters? Thank's for the help!
I was out of order the other day over a pedantic difference in terminology,  so I'll let one on you Northern Hemispherians explain why he needs to change his rooters!
Logged
 Logged
moparman70
$ Contributor
Sr. Member
Offline Offline
Gender: Male
« Reply #16 on: May 29, 2012, 03:27:09 AM »
Note sure where you got the idea to put on ABS -- I read through the post and no one suggested that... you would have to have a complete setup to do something like that -- wheels with sensors -- all the electronics.
Everyone is saying change the brakes to the more modern monobloc calipers and to a 14MM Master.  R1 of certain vintage ( read through the posts) work.  I concur as it is the most simple one to do mostly just remove and replace.  The hardest part is just bleeding the system.  The results from OEM dual pistons that you have on is fantastic.  The feel is great - one finger braking if you want.  And you don't have to change rotors.
Here is an example -- Derek just completed ( now he change his front end too as he has an 86 and you need to do that for this mod on an 86) ..you can still upgrade the front end but you'll do it for other reasons if you want.
http://www.fjowners.com/index.php?topic=6771.msg59793#msg59793
Logged
$ Contributor
Super Hero Member
Offline Offline
« Reply #17 on: May 29, 2012, 08:16:45 AM »
If you already have a 93 ABS bike, then your brake mods would still include SS lines, and new calipers, and maybe new master cylinder.  This assumes that the ABS is still working.
I don't think most here are against ABS except that when it fails it is horrendously expensive to replace the ABS system parts.  The rotors for the ABS bikes are different than the non-ABS bikes, and I don't believe that there are any aftermarket replacements.
Most who have had their ABS fail have ended up bypassing or removing it rather than pay $2K or more for new ABS bits.
Logged
baldy3853
$ Contributor
Hero Member
Offline Offline
Gender: Male
« Reply #18 on: May 29, 2012, 12:52:48 PM »
Had the 93 model non AbS did the blue spots
and master cylinder upgrade and Stainless lines
As my first mod, after several very long trips of over 5000 K's my
next and most important mod because unless your
 comfortable on the bike you are to easily distracted is
the seat
Logged
fjfanatic
$ Contributor
Jr. Member
Offline Offline
Gender: Male
« Reply #19 on: June 03, 2012, 07:11:27 AM »
Thanks for the recommendations guys. I have been in the middle of a move and don't have internet yet at the new house. I'm at the old house for a couple of days to watch the movers pack all our stuff.
First order of business will be carb rebuild and sync - she won't hold idle and leaks gas after shutoff.
Second will be replacing all the worn out panel grommets. easy and fairly cheap.
Third will be the front brakes and lines - new master cylinder?
after that I think a wheel swap and shock upgrade would be in order.
Logged
yamaha fj rider
$ Contributor
Hero Member
Offline Offline
Gender: Male
My 93 FJ
« Reply #20 on: June 03, 2012, 12:30:23 PM »
Thank's for the great feedback! My 93 came with abs. It has stopped working long ago and I am not going to fix it. Just seemed like abs was a bad word here. I now have front calipers off of a 02 R1 and an planing to order master cylinder off of fjr1300. Then new stainless lines set. Are there any difference in calipers from the blue dot, gold dot, or other colors? Thank you again. I am also planing headlight mod and new shock later this year. If I do anything with the front forks that will take some investigation.
Logged
Lets go riding send me a pm. Remember the glass is not half full or half empty. Think room for alcohol !!!!!
Yamaha WR500 Dirt Bike
yamaha XS500 cafe bike (work in progress)
Yamaha YZ490
Suzuki DRZ400S
93 FJ1200
 Logged
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #21 on: June 03, 2012, 04:36:15 PM »
Quote from: yamaha fj rider on June 03, 2012, 12:30:23 PM
Except for the color the Blue and Gold dots are the same. You could remove the dots and make them any color you want.
Logged
The glass is not half full, it was over engineered.
FAQ Moderator
$ Contributor
Super Hero Member
Offline Offline
« Reply #22 on: June 03, 2012, 06:53:28 PM »
Quote from: FJmonkey on June 03, 2012, 04:36:15 PM
PINK DOTS FOR PINK STRIPES
That is all.
Logged
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #23 on: June 03, 2012, 08:39:29 PM »
Quote from: andyb on June 03, 2012, 06:53:28 PM
That is all.
Baldy, your next upgrade, it will match your new shirt....
Logged
JCainFJ
$ Contributor
Full Member
Offline Offline
Gender: Male
« Reply #24 on: June 03, 2012, 11:16:08 PM »
 Yes there are. The first generation Blue dots are the ones with the external fluid transfer line. These were fitted to the 1997-2007 YZF600r and the 1997 YZF1000r.These weigh the most and the fluid fitting is in a different location then the others, these can be the cheepest to buy. The Blue dot calipers from the early R6 and R1 do not have the external line. These can be a good buy too. The Gold dots are from the 2002 and 2003 R1 have lighter pistons and do give the best feel. I have used all 3 of these calipers on our bikes. The best setup I found is Gold dots (100 g lighter then the R1 Blue dots), stock Gold dot Sumotomo GG  pads, stainless lines, and a late model R1 radial mastercylinder.
All of these calipers are very good, and they all can use the same pads. The Gold dots are just the best.
Logged
MyFirstNameIsPaul
Full Member
Offline Offline
Gender: Male
Morgan Hill, CA
WWW
« Reply #25 on: June 04, 2012, 03:33:03 PM »
Personally, I can't stand stock seats. That's always the first thing I change on a bike. The second thing I change is the suspension, as all stock suspension is garbage. After that I do the brakes.
Logged
1993 FJ1200
2003 ZX-6R (x2)
yamaha fj rider
$ Contributor
Hero Member
Offline Offline
Gender: Male
My 93 FJ
« Reply #26 on: June 04, 2012, 11:27:53 PM »
Quote from: JCainFJ on June 03, 2012, 11:16:08 PM
Thank you JCainFJ!!!! It really helps having your experience with these mods.  good2
Logged
Yamaha YZ490
Suzuki DRZ400S
93 FJ1200
jykkeh
Jr. Member
Offline Offline
I only try to burn rubber one kilometer
« Reply #27 on: June 08, 2012, 01:44:31 PM »
These are my bike brakes, no i can tell you, i have brakes.
Logged
fj11.5
$ Contributor
Super Hero Member
Offline Offline
Gender: Male
nearly how I want her 84 Fj1100 ex ambulance
« Reply #28 on: June 08, 2012, 05:15:09 PM »
Quote from: jykkeh on June 08, 2012, 01:44:31 PM
   what calipers are they , I've seen  ones like those on eBay  off a Suzuki ?? wondered if they would be as good as blue dots or better
Logged
84 Fj1100  effie , with mods
yamaha fj rider
$ Contributor
Hero Member
Offline Offline
Gender: Male
My 93 FJ
« Reply #29 on: June 08, 2012, 09:18:57 PM »
WOW who doesn't want six piston calipers? Waht are they off of please tell? wacko1
Logged
Yamaha YZ490
Suzuki DRZ400S
93 FJ1200
 Logged
Pages: 1 [2] 3   Go Up
  Print
« previous next »
Jump to:
Help Marsh support the hosting costs of this website - ANY amount helps!
(also removes banner Ads from website)
Loading...
