carb sync tool
Started by FJdude, May 17, 2012, 09:45:00 PM
FJdude
So I'm thinking about investing in a nice fancy carb sync gauge set. I have tried the homemade ones and failed so I have been looking at the ones with the gauges over the mercury ones, just because it seems like over time the gauges will have a longer life....that's just what I have read.
Have seen a lot that are similar to this type -
http://www.motorcycle-superstore.com/1/4/65/21754/ITEM/Emgo-Carburetor-Synchronizer.aspx
What do you guys think? Is this one legit? Worth the money?
Quote from: FJdude on May 17, 2012, 09:45:00 PM
See what RPM offers as well...Randy builds FJ engines and knows a thing or two about carb syncing.
http://www.rpmracingca.com/proddetail.asp?prod=Carb%3A4gage
http://www.rpmracingca.com/proddetail.asp?prod=Carb%3Asyncpro
FJdude, I have a set of those.
My observations are that they are very sensitive (you have to run the restrictors almost fully closed to prevent needle flutter), and they are very sensitive when zeroing the gauges to start with.
Apart from that, they worked just fine.
I tried gauges years ago but I find the vertical columns on the sticks easier to read than 4 gauges with fluttering needles. After a knuckle head move sucking the liquid mercury out of my last stick, I moved to a Morgan Carb Tune which is my current fav.
Note to Leon.... Do not blip your throttle with the stick connected.... Like me, you will wonder where all the mercury went.
Quote from: Pat Conlon on May 17, 2012, 11:23:13 PM
+1 there is no better -seems to me.
You could always buy some mecury on Craigslist:
http://www.chron.com/home/article/MN-recovers-64-lbs-mercury-offered-on-Craigslist-3566160.php
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
Never used one, but friends who have them rave about them.  The Twinmax.
http://www.ascycles.com/detail.aspx?ID=2146
'06 KTM 200XC
'43 BSA WM20
I have a set of gauges exactly like that, but I got them from JC Whitney on sale for $15 lots of years ago.  They work fine but are touchy and do require you to keep re-setting them so X units of vacuum gives an equal reading on all gauges.
The set of gauges Randy sells looks to be better quality.
I've used mercury sticks before and they are also ok.
If I were going to replace them, I'd get the Morgan Carb-Stix.
FJdude
Sounds like everyone here loves those Morgan carb sticks...I would not be opposed to getting mercury sticks I just read somewhere that after X amount of years the mercury dries out and good luck finding mercury or wanting to replace it.
It looks like the Morgan carb sticks run about $98, I would not mind spending an extra $20 or $30 on something that will make my life a whole lot easier, but I also plan on keeping these things for a very long time as I rebuild motors (not just motorcycle, outboard, and farm equipment as well). So I would like what ever I am getting to last, be durable, and easy as possible.
Let me know what you guys think and thanks you guys are great!
The Morgan Carbtune meets all your requirements.
Get it.
bigbore2
Mercury doesn't dry out, it evaporates, so volatile it will work its way thru glass given enough time.
More importantly, it spills.  And that's annoying.
The morgan rocks to use.  It sucks to pay for, and it sucks to wait for if they're shipped from overseas.  Once it's in your hands, it makes synching carbs laughably easy.
FJ Flyer
Go with the Morgan Carbtune.  You won't regret it.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
oz.fj
 +6 on the Morgan
I had it shipped to me Down Under in 8days
By 8.3 days I was cruising vibe free
and it really is easy peasy :good2:
  Darran
89 FJ 1200 Shiny Black
89 FJ 1200 x 3 Red White Silver
92 XR 250
Life is pretty straight without twisties
Toy4Bob
I bought and used the Motion Pro SyncPro Carb Tuner... worked like a charm
1989 Yamaha FJ1200
2011 Kawasaki Vaquero
