bought 86 FJ with 10486 miles for $600
Started by giantkiller, June 09, 2012, 11:10:36 AM
Been in storage for 10 years. Everything that has to do with brake fluid is leaking... So starts the changes. 2007 GSXR1000 front end, 92 GSXR750 rear wheel, manual petcock, Electrically adjusted stearing damper, lithium battery,(RPM parts, voltage regulater, clutch slave cylinder,integrated turn taillight, carb kit) GIVI rack and bags, trailtech voyager for speedo, red ss braided brake and clutch lines. I think I have all of  the parts together. The fork extensions are being reworked(too thick hitting in a couple of spots). Last thing I have to make is the risers to match the fj handle bars to be welded to GSXR clippons. Oh yah and mount for voyager. I figure it will be atleast 40 lbs lighter(without GIVI).I'm hoping to have it running in a couple of weeks (so it'll probably be a couple of months) Wish me luck
fj11.5
sounds like fun mate, what's the speedo, a digital one ??
84 Fj1100  effie , with mods
Yah it's a trail gps and it also reads off a magnetic speed pickup. Plus its got engine temp, tach and all kinds of other things it does. I'm useing one unit for my atv's, a mini chopper, and the FJ. You can get the sending unis from them for each machine.
moonrunnah
Quote from: giantkiller on June 10, 2012, 08:14:49 AM
what is the name i would like to find one
When in doubt throttle out
Trailtech voyager It's fairly new. New to me too. Haven't used the gps for trails yet. Is not for street. Hope they develop software for street use someday. But for now it's a great speedo and moniter for engine
digital dash? I really like my Acewell ... got one on my DRZ and FJ
Trailtech allows me to justify the cost. Since I'm going to use it 1 for 4 different machines. I've wanted one for my 700 raptor since they came out. For trail gps. And I realized I can use it for speedo and engine monitoring on other machines
fj11.5
will check out the trailtech , but the acewell looks fantastic  :good2:
moonrunnah
http://www.btosports.com/p/Baja-Designs-Speedometer
this is cheaper than the trail techs i saw
would i have to buy anything else with this to work on my fj
Quote from: moonrunnah on June 10, 2012, 07:42:14 PM
Nope.... everything you need comes with it.
moonrunnah
wow that does not seam like a bad deal then
Got GSXR wheels back from powder coating. I put the bearings in them (I'll probably be replacing the rear again I got them Little too tight) mounted and balanced the tires last night. Made the steering stop, and bracket for the electric adjusted steering damper, tacked them up. Damper fits almost perfect under fairing. Put the toggle switch for it where rocker switch for reserve used to be. Painted the Gsxr front fender to match FJ red.
moonrunnah
Quote from: giantkiller on June 12, 2012, 09:20:50 AM
cant wait to see compelted pics of your bike
ive been wanting to mod mine but with little time i have i like to be riding  :good2:  come this winter ill be doing most of my work on it
Well its official my fj is going to be a YAMASUZONDA. I just bought a f4i rear shock off ebay. Should be here Tuesday.
