Idles fine but dies on acceleration.
Started by wJeffreyCox, March 29, 2013, 10:07:24 PM
wJeffreyCox
1990 FJ1200 - after riding 5 miles and stopping and turning off engine (getting gas), on restart the bike idles fine, but dies when given gas. After waiting 15 minutes it runs fine again. This is a repeatable problem. Any ideas why?
possible the fuel tank breather is blocked, or you have a kinked fuel line, , open the fuel cap and go for a ride see if it happens, , and make sure your fuel line is ran right,, should be info in the files section
Can you hear the fuel pump when you turn the ignition on ? Be aware there is or should be, a fuel filter under the fuel tank. Things to check anyhow. Keep us posted.
yamaha fj rider
I had a problem like this once, turned out to be some water had gotten in to the tank. We drained all the fuel, fresh gas, problem solved. I don't know if this is your problem but it was simple fix and it might eliminate one possible source of the problem. Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
Windmill
Quote from: yamaha fj rider on March 30, 2013, 10:17:58 AM
Kurt
Definitely something to check anyway, especially if kept out in the weather. Mine had a pint and a half of water in it when I got it, ran awful funny  :biggrin:
