General Category => Modifications => Topic started by: Brian S on April 16, 2012, 12:35:13 PM
Title: Windshield for tall guys
Post by: Brian S on April 16, 2012, 12:35:13 PM
Any other tall guys on here that found a windshield that works well for them. I'm 6'8" and would something that gets my face out of the wind blast
with the least weird buffeting effect. Sorry if I posted in the wrong place this is the first forum I ever joined.
Title: Re: Windshield for tall guys
Post by: Zwartie on April 16, 2012, 01:27:33 PM
Brian,
OK, I'm about a foot shorter but the previous owner of my '92 FJ is 6'4" and had installed a Laminar Lip on the stock windscreen. He said it made a big difference for him as it raises and smooths out the air flow. Often times taller windscreens or ones with a "flip" at the top can tend to cause more buffeting.
Here's a picture of my fairing with the Laminar Lip installed.
(http://www.laminarlip.com/fj12-92.jpg)
For more info go to: www.laminarlip.com (http://www.laminarlip.com)
Hopefully some of the taller riders in the group can give you their first-hand experience.
Good luck!
Zwartie
Post by: skymasteres on April 16, 2012, 03:08:22 PM
Well, I got one am very interested in hearing any feedback you hanger I'm how the laminar lip performs.
Post by: Zwartie on April 16, 2012, 03:40:30 PM
You may want to explain the meaning of "you hanger I'm how the laminar lip performs". I'm guessing you either typed your message on a phone with auto-complete or your spell check is possessed.
Zwartie
Post by: roverfj1200 on April 16, 2012, 07:03:27 PM
W#hat year FJ???
Post by: skymasteres on April 16, 2012, 11:01:12 PM
Quote from: Zwartie on April 16, 2012, 03:40:30 PM
Zwartie
Correct on both counts actually. The damn thing has a mind of it's own. It should have read. "Well, I for one am very interested in hearing any feedback on how the laminar lip performs."
But seriously. I have been spoiled by the rifle faring on my Magna and if this is a way to improve the air pocket that surrounds the ride I would be greatly interested...
Post by: Brian S on April 16, 2012, 11:21:45 PM
Quote from: roverfj1200 on April 16, 2012, 07:03:27 PM
W#hat year FJ???
It's a 89 fj. That laminar lip looks interesting, think I'll doe some research on that one.
Post by: roverfj1200 on April 16, 2012, 11:33:40 PM
Quote from: Brian S on April 16, 2012, 11:21:45 PM
W#hat year FJ???
I'm 6'2 and use a eagle screens touring screen. The screen gives good protection and weather too. But the turbulence around the helmet creates a lot of noise. I use a HJC flip. My old screen had a touring lip which did the same. Also take in to account that a tall screen on the 3cv fairing  will put undue pressure on the attachment points. The touring screen I have is showing this.
(http://i576.photobucket.com/albums/ss204/roverfj1200/TLC/P1010013.jpg)
This the best pix I have online right now. bit hard to see I know.
I have looked other screens with a lip as the above shows so will be interested in this thread to.
Cheers.
this will show the height a bit better.
(http://i576.photobucket.com/albums/ss204/roverfj1200/bike/p8070027.jpg)
Post by: baldy3853 on April 17, 2012, 01:41:39 AM
Guys my mates 6'5 and runs the standard
screen on his 95 but he has the laminar lip on his
FJR and he reckons its the best thing since sliced bread!
Title: Re: Windshield for tall guys (and shorter guys)
Post by: ribbert on April 17, 2012, 07:36:13 AM
I also bought an Eagle Touring screen (not cheap, about $240 delivered) for my '93 to replace the "finned" standard one and only did a couple laps of the block before removing it again.  It wasn't as noisy as the standard one but I copped a lot more wind in my face, I'm 5'10".  So, with original screen refitted I sort of solved the problem with earplugs. However, I would like to find a solution to the the buffeting also.  When I duck down a few inches it's great, when I stand on the pegs in clean air it's great.  I like the theory of the Laminar Lip. I believe the solution lies in not so much deflecting ALL the air but equalising the pressure behind the screen which the lip does by sitting off the screen allowing air to pass under it.  I have a #2 bike with an old screen I'm experimenting with. This includes lips of all shapes and sizes and a hole near the base of the screen.  If anything good turns up I'll report my findings.
Post by: The General on April 17, 2012, 08:29:43 AM
Quote from: ribbert on April 17, 2012, 07:36:13 AM
  When I duck down a few inches it's great, when I stand on the pegs in clean air it's great.  I like the theory of the Laminar Lip. I believe the solution lies in not so much deflecting ALL the air but equalising the pressure behind the screen which the lip does by sitting off the screen allowing air to pass under it. Noel
+1. Just received a GIVI screen (They don`t make them anymore) and plan to put an adjustable lip on it. I too found earplugs the best solution to date - but doesn`t fix communications over 90klm/hr. (Also experimenting with quieter helmets) On the FJ the problem is exacerbated by the distance between helmet & screen. Interestingly Brett (FJ mate of Baldyy`s) told me on the weekend that yamaha went to a lot of trouble to design the tourer finned FJ screen due to instability at really high speeds. (Hadn`t heard of that before but it does make some sense) At 6ft 8 the only thing that will keep ya face outa the wind is a cab. - helmet design will be critical I think. (You`d have ta wear one inside tha house at my place  :sarcastic: )
Post by: Arnie on April 17, 2012, 10:30:11 AM
I'm only 6'1", but have a pretty good solution to the wind and buffeting on my bike.
Using the standard finned OEM screen I've added an extension that retains a "slot" between the fins and the extension.  This give an inner flow of air that helps deflect the airflow up and over.
I frequently wear an open face helmet and its fine.  MY HJC flip is a bit noisier, but not bad.
The extension sits 7" higher than the stock screen.  This can be adjusted for various heights by varying your mount points through the fins.
Numbers in the pic are in mm.
(http://fjowners.com/gallery/2/99_14_04_11_8_58_15.jpeg)
(http://fjowners.com/gallery/2/99_14_04_11_9_00_34.jpeg)
Post by: cyclenutk75 on April 17, 2012, 11:39:18 AM
Quote from: Brian S on April 16, 2012, 12:35:13 PM
Any other tall guys on here that found a windshield that works well for them. I'm 6'8" and would something that gets my face out of the wind blast with the least weird buffeting effect.
Brian, welcome to the forum.  I put a Zero Gravity sprot touring screen on my 89.  It's about 2-3" taller than OEM and moved the wind blast from just under my chin bar to the top of my helmet  - no objectionable buffeting.  However, I'm 5'9".  I looked on the web and found you can still buy the ZG screen new for about $100.  Perhaps coupling this screen with a laminar lip would be the cat's ass.  Good luck in your search.
GT
Post by: WhiteBeard on April 17, 2012, 05:55:05 PM
Remember reading a lot about replacement windshields on this forum previously.
Having been looking for a taller windshield for my '85 myself, here are some of the threads that I've saved for future reference:
http://www.fjowners.com/index.php?topic=3264.0 (http://www.fjowners.com/index.php?topic=3264.0)
http://www.fjowners.com/index.php?topic=2702.0 (http://www.fjowners.com/index.php?topic=2702.0)
http://www.fjowners.com/index.php?topic=3608.0 (http://www.fjowners.com/index.php?topic=3608.0)
http://www.fjowners.com/index.php?topic=843.0 (http://www.fjowners.com/index.php?topic=843.0)
http://www.fjowners.com/index.php?topic=1019.0 (http://www.fjowners.com/index.php?topic=1019.0)
http://www.fjowners.com/index.php?topic=1335.0 (http://www.fjowners.com/index.php?topic=1335.0)
http://www.fjowners.com/index.php?topic=5077.0 (http://www.fjowners.com/index.php?topic=5077.0)
http://www.fjowners.com/index.php?topic=5939.0 (http://www.fjowners.com/index.php?topic=5939.0)
http://www.fjowners.com/index.php?topic=3500.0 (http://www.fjowners.com/index.php?topic=3500.0)
Seems like some people have experienced less wind buffeting by using a windscreen shorter than stock.
You could try removing your existing screen to see if this hold true for your specific height.
Some suppliers of aftermarket windshields:
Eagle Screens (Australia)
http://www.eaglescreens.com.au/?productcats=yamaha (http://www.eaglescreens.com.au/?productcats=yamaha)
Standard or windlip
Zero Gravity (U.S.A.)
http://www.zerogravity-racing.com/windscreens.php?expandable=0 (http://www.zerogravity-racing.com/windscreens.php?expandable=0)
Standard
Lockhart Phillips (U.S.A.)
http://www.lockhartphillipsusa.com/store/FJ1200-86-87.html (http://www.lockhartphillipsusa.com/store/FJ1200-86-87.html)
Standard
Skidmarx (U.K.)
http://www.skidmarx.co.uk/product.php?id_product=20790 (http://www.skidmarx.co.uk/product.php?id_product=20790)
Standard or tall
Gustafsson (U.S.A.)
http://www.bikescreen.com/proddetail.asp?prod=YamahaFJ1100%6084%2D%6085Touring (http://www.bikescreen.com/proddetail.asp?prod=YamahaFJ1100%6084%2D%6085Touring)
15% discount applicable to FJ members (read this thread (http://fjowners.com/index.php?topic=93.0))
MRA Windshields from Twisted Throttle (U.S.A.)
http://www.twistedthrottle.com/trade/productlist/344/ (http://www.twistedthrottle.com/trade/productlist/344/)
Powerbronze (U.K.)
http://www.powerbronze.co.uk/907122/818268/---YAMAHA-FJ1100-84-85.model (http://www.powerbronze.co.uk/907122/818268/---YAMAHA-FJ1100-84-85.model)
Standard and flip
Cheers!
/Nat
Post by: Pat Conlon on April 17, 2012, 06:09:08 PM
Great job Nat ..... I'm going to copy and paste your post over in the Modification Files for future reference. Thanks amigo!
Post by: Brian S on April 17, 2012, 11:35:22 PM
Think I'm going to give the laminar lip a try. Who would of thought plastic pieces could be so expensive. Thanks for the advice guys.
Post by: Brian S on April 18, 2012, 12:00:15 AM
I'm still reading through posts, wow you guys really come though with the info. The donation I made to this site might be the best money I spent on this bike so far.
Post by: Pat Conlon on April 18, 2012, 12:13:09 PM
Quote from: Brian S on April 18, 2012, 12:00:15 AM
It is very much appreciated Brian!   Bandwidth and servers cost $$$
Post by: ELIMINATOR on April 18, 2012, 01:24:40 PM
http://www.skidmarx.co.uk/product.php?id_product=20793 (http://www.skidmarx.co.uk/product.php?id_product=20793)
OK it's made in the UK, I'm pleased with my flip up screen.
Post by: WhiteBeard on April 19, 2012, 05:54:52 AM
Quote from: ELIMINATOR on April 18, 2012, 01:24:40 PM
Is that the screen that's on your bike in this post (http://www.fjowners.com/index.php?topic=3500.msg52258#msg52258)?
Just being curious as to how it looks...  :blush:
Post by: WhiteBeard on June 04, 2012, 04:36:39 PM
Does anybody know of an after-market windscreen for the FJ1100 that has a sharper angle, more like the FJ1200?
Post by: Sabre093 on June 04, 2012, 05:45:30 PM
Kidmarx The Screen on the U.K black and blue FJ is that a Skidmarx's unit?
