Fuel injected fj12 looooooooong term project
Started by Pheasantplucker, February 15, 2021, 02:31:09 AM
Pheasantplucker
I've been looking at the T Rex fj1200 race bike, bad move!
Then, I pick up a free Fj! A very rough free fj.
So, I started to chop it up straight away and fit whatever I had in the shed.
Did I say this was a long term project?
Nice!  Like the subframe mods  :good:
What TBs are those?   Mods to the rack?  Also looks like a bespoke fuel rail?
Pheasantplucker
Well.......
GSXR 600 k1 throttle bodies spaced apart in the middle, throttle mechanism moved to the middle because it hit the frame!
Throttle bodies turned down a little to make them a little easier to fit but still a little difficult to get on!
GSXR 600 pump mounting flange will be tigger into the bottom of the FJ tank, still not decided about trigger wheel but I'll be using all the Suzuki sensors, nice neat TPS is standard Suzuki.
Gsxr1000 k5 swingarm but I have a later 600 one to go in because the chain run will be better.
Modifying a xr69 seat to fit at the moment :dash2:
Do you have a cam signal so as to run sequential injection, or do you plan on batch injection?
Which ecu are you planning?
Very nice!
You can use the XJR trigger wheel.  24-2 if I remember correctly.   I have also used a ZX636 trigger wheel, but is requires a few mods and doesn't fit as neatly as the XJR wheel.  The ZX636 was a 24-1 wheel, but modifying it to 24-2 made starting easier and more reliable - especially if the battery wasn't 100% fully charged.
Also - depending on the ECU you want to use, it may work better to go with a Hall effect crank sensor vice the stock VR.   I've used VR with microsquirt, megasquirt3X and Holley HP ECUs.   The more I learn about VR sensors, the more I realize the need for application specific filtering.  I have had several instances of either hard starting or of ECU resets at high RPMs.  Some of these were difficult/impossible to discern when happening - and could be hard to find in the data logs - in retrospect I'm pretty sure a lot of the issues were related to the VR sensor.
Good luck!  Keep us posted on progress!
Pheasantplucker
Autotune Ecu looks favourite at the moment.
Don't think sequential will be an option as I don't think I'll fit a cam position sensor.
Looking at modifying a fz1 24-2 wheel but as this is my first attempt at injecting anything could happen.
Slight hiccup at the moment, just discovered the frame is bent at the headstock, I know the previous owner had a pelvis breaking argument with a car!
I have a 1TX that might now be the project bike!
I'd really suggest the crank wheel from a fuel injected XJR - doesn't need to be modified at all.  Probably easier for you to get one than it is over here!
Well, hopefully that means you have a spare motor - work out the EFI issues on one, and build up the other into the fire breather once you have the basic tune sorted out!
I'm not familiar with the Autotune brand - that's usually a feature they boast.  Tried google - just found various ECUs that have the feature.  I'd like to check it out and see what it is and is capable of.
FYI, I have the XJR efi rotors in stock.
Pheasantplucker
Thanks for the advice.
As I said this is all new to me, just seemed like a fun thing to do!
I have a Xjr rotor, somewhere, I've been planning for a while!
I must drag the other bike down from the barn over the weekend, back to work so not too much spare time.
Pheasantplucker
Just a thought!
Some of you have fitted injection, has anyone perfected a way of getting a good signal from a cam sensor?
Pheasantplucker
Quote from: racerrad8 on February 22, 2021, 12:13:17 AM
I have a rotor but i'm Short of a good onset front sprocket.
Pheasantplucker
Quote from: fj1289 on February 21, 2021, 09:25:21 PM
Autotune.fi a few on the old school Suzuki site have used autotune Ecu to good effect.
Quote from: Pheasantplucker on March 05, 2021, 01:29:23 AM
Just a thought!
The XJR uses a backbone frame, thus a cam sensor can fit....not so on our perimeter frame. The sensor housing runs afoul with the frame rail.
RPM used batch injection on their bike, as I think Chris also uses on his race bike.
Quote from: Pat Conlon on March 05, 2021, 08:20:19 AM
Just a thought!
Move the frame rail
Quote from: ribbert on March 05, 2021, 08:29:47 AM
Just a thought!
Move the frame rail
.......and the fairing?
