Colin's FJ1200
Started by FJ1200W, July 18, 2021, 01:08:14 PM
FJ1200W
Quote from: Pat Conlon on August 16, 2021, 03:05:43 PM
Quote from: FJ1200W on August 16, 2021, 08:20:20 AM
Question: The ignition "boost" is disconnected, any reason to connect it?
If the diaphragm passes the suck test, go ahead and hook it up...it sure will keep your plugs clean.
Thank you - I'll give it a test.
Much appreciated!
Columbia, Missouri
USA
Old Rider
Nice work ,but you didn't forget the float needle valve on carb 1 ? i cant see it in the pictures :scratch_one-s_head:
FJ1200W
Quote from: Old Rider on August 17, 2021, 02:44:40 AM
Good catch - The retaining spring was missing from the float valve. I pulled one off the old carbs, cleaned it up and installed it.
I'm impressed!
Columbia, Missouri
USA
FJ1200W
Here's the old and "new" and clip
Columbia, Missouri
USA
FJ1200W
Quote from: Dads_FJ on August 02, 2021, 11:05:18 AM
This fits the bill and is the one I used on my '89.
Facet - FPF-40178N   12V, 2-3.5PSI
Many thanks!
Did you go with the stock location?
Columbia, Missouri
USA
FJ1200W
Final version, I'm not going to do it, I'd have to order 10 sets and resale would be close to $100.00 a set with shipping.
If I'm going with a simple block, I'll do it myself......
Columbia, Missouri
USA
Old Rider
Quote from: FJ1200W on August 17, 2021, 04:31:44 PM
Steve i knew a good mechanic like you had full control ! :drinks:
FJ1200W
Still working on the fuel pump placement.
It's close, but just not right.......
Facet calls for a 72 micron filter, I'll probably going with more filtration. I have a 12 micron inline, but sure don't want to restrict flow to the pump.
Columbia, Missouri
USA
FJ1200W
Made some progress today.
Petcock was nasty. Was able to carefully disassemble it, clean it and reassemble. Seems to be working. The filter, I pulled it out. I may replace the petcock all together as there is an inline filter before the pump, and an inline shut off.
Took a test ride, eff'ing valve cover gasket popped and sprayed oil all over my bare leg.
Test ride, shorts, sandals, tee shirt, no helmet, no sunglasses, it was sort of one of those moments I questioned my judgement.
I got over it.
Columbia, Missouri
USA
Very good Steve, how is the fuel pump controller working out?
FJ1200W
Quote from: Pat Conlon on September 03, 2021, 10:08:59 AM
Thanks - it seems to work as it should.
I was pleased to find the tach/coil connection could be done near the ignition control box. I soldered the wire in place, will probably do the same to another I used a connector on. All of the connections were pretty straight forward.
I'm surprised how quiet the fuel pump is. I just hope it flows enough at speed.
I did connect the vaccum line to the ignition box - I've not looked to see what it does to the ignition curve - If it's just for emissions, I'll disconnect it.
Any preference?
Columbia, Missouri
USA
"If" the diaphragm passes the suck test....no preference.
That extra 10* of advance when the throttle plates close, sure cleans off the plugs.
Old Rider
Quote from: FJ1200W on September 02, 2021, 06:45:22 PM
I got over it.
Good humor Steve what really made me LOL was the picture of the petcock filter i guess you can say that is well used .
Quote from: FJ1200W on September 02, 2021, 06:45:22 PMMade some progress today.
Steve,
Just gotta ask, why would that happen?  All pistons leak combustion gasses to some extent.
Is there no crankcase ventilation that works, with that engine?  Never heard of this malfunction before.
Seems to me, if the valve cover gasket did not blow out, then some other seals or gaskets would soon blow out instead.
FJ1200W
Quote from: red on September 03, 2021, 08:40:17 PM
Steve,
I've had them blow out on cars and bikes.
I'm not sure why on this instance, as it's got a very free flowing filter on the vent.
I chalk it up to "shit happens" and that I probably didn't install the gasket properly (which really pisses me off because I spent a lot of time making sure the damn thing was perfect).
In the past it usually was due to either an obstruction in the crankcase ventilation system (as you mentioned) or a really big ka-pow from the deep dark depths.....
Columbia, Missouri
USA
